Properties Panel
The Properties panel shows metadata names and values for the selected object in the Contentブラウザ.
It is possible to view metadata organized in categories or in alphabetical order. The Properties panel can be used to modify an object’s metadata when possible, when objects are Checked-Out.
For managed libraries, if a document is not retrieved in the current workspace, the
value for the document in the Property panel is not retrieved. When retrieved, the
document can be accessed by the pull-down menu available in the value
field.
注: Based on the selected file type and active HyperMesh client, only the appropriate integration
options will display.
