ExecQuery
Query the library manager for content based full text search.
<generic data manager handle> ExecQuery <query string> <content interface list>
Type/Class
Query
Query the library manager for content based full text search. Searches all the
metadata and the contents of the files in the library.
- generic data manager handle
- Generic data manager handle
- query string
- String to query in the library
- content interface list
- Content interface list handle
注: The result of the query will be passed to the content interface handle. The size
of the content interface list will give the size of the returned list. Refer to the
example below. To check if the query was successful or failed use the command
hwLMStatus_GetMessage.
Examples
set gdm [DMDirector_OpenWorkspace $director $ws $repoh 0]
set qryhandle [$gdm GetQuery]
set stringtosearch "MS6000"
set clist [ContentInterfaceList]
set status [$gdm ExecQuery $stringtosearch $clist]
set cilistsize [ContentInterfaceList_size $clist]
