Library_GetLDBFile
Get the LDB file path and name.
Library_GetLDBFile <library handle>
Type/Class
- library handle
- Library handle used to get the path and name of the .ldb file.
注: The .ldb file gives you the path where the library is
located.
Examples
set altairHome [file dirname $::env(ALTAIR_LIB_MGR_PATH)]
set fileDefaultSettings [file join "$altairHome" hw tcl hweDataMgr librarymanager.xml]
set settings [CreateDefaultSettings "$fileDefaultSettings"]
set director [new_DMDirector $settings {C:\Documents and Settings\username\.Altair\11.2\hwe\organize\master\master.db}
set liblist [LibraryList]
DMDirector_GetLibraries $director $liblist username ""
set lib [LibraryList_at $liblist 1]
set libpath [Library_GetLDBFile $lib]
