Publish to Teamcenter-Upload to PDM
You can upload contents from Collaboration Tools libraries, meshes, solver files, simulation results, and so on, directly into your Teamcenter PLM system.
- Select a content in your workspace, retrieved via Get or Check-Out, having an attached document, right-click and select Upload to PDM from the コンテキストメニュー.
- Select the desired Teamcenter repository, or add a new one.
- Click Login.
- To query for the Item Revision your simulation file will be attached to, enter text to search on in the Query field and select which attribute to search from the By list.
Click Simple query.
Items matching the query criteria are returned.
- Select the desired item revision.
- Select the Type and Tool used from the provided lists.
- オプション: Enter a Description.
Click Upload.
If the upload is successful, you will see a dialog that says that the file was uploaded successfully, and you will see the new file associated with the chosen item revision.注: The Type, Tool used and Reference fields are required by Teamcenter and the acceptable combination of choices dictated by your Teamcenter implementation. Incompatible selections will result in the inability to publish the selected file. You should contact your Teamcenter administrator for additional information regarding valid selections.
