/DRAPE
Block Format Keyword This option is used to read fiber orientation changes and thinning for each of the plies which are usually the result of a manufacturing process simulation.
Different angle change, and thinning can be defined for each slice of the element set.
/DRAPE/drape_ID
drape_title
For each element set, add:
Entity Entity_ID Thinning_1 θ drape_1
If there is more than one slice for the element set, add:
Thinning_i θ drape_i
Definition
drape_ID Drape identifier.
(Integer, maximum 10 digits)
drape_title Drape title.
Entity Must be left justified.
SHELL
The entity is a 4 nodes shell element.
SH3N
The entity is a 3 nodes shell element.
GRSHEL
The entity is a group of 4 nodes shell element.
GRSH3N
The entity is a group of 3 nodes shell element.
(Integer)
Entity_ID Entity identifier.
(Integer)
Thinning_1 Ply thinning factor for the first slice.
(Real)
θ drape_1 Ply orientation change for the first slice.
(Real)
[ deg ]
Thinning_i Ply thinning factor for the slice i.
(Real)
θ drape_i Ply orientation change for the slice i.
(Real)
[ deg ]
  1. The drape is used in /PLY and /PROP/PLY (TYPE19) to take into account the manufacturing process on the orientation and thickness of each slice of the elements. See Example (Substack with /DRAPE) in /STACK. There is a minimum of 1 slice per element.
  2. The number of integration points defined in /PLY and /PROP/PLY (TYPE19) is ignored and replaced by the number of slices defined in /DRAPE.
  3. The orthotropy angle is defined as follows from the reference vector (Anisotrophy in Layer (Ply)) defined in the stack:
    ϕ = ϕ s + ϕ i + Δ ϕ + θ d r a p e MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHvpGzcq GH9aqpcqaHvpGzdaWgaaWcbaGaam4CaaqabaGccqGHRaWkcqaHvpGz daWgaaWcbaGaamyAaaqabaGccqGHRaWkcqqHuoarcqaHvpGzcqGHRa WkcqaH4oqCdaWgaaWcbaGaamizaiaadkhacaWGHbGaamiCaiaadwga aeqaaaaa@4B66@
    Where,
    ϕ i
    is defined per ply in stack
    ϕ s
    is defined on the element
    ∆ ϕ
    is defined on the ply
    ϕ d r a p e
    is defined in the drape table
  4. The ply thickness ti of the element as defined in the ply is scaled using the thinning factor Thinning for each slice.
