/FAIL/ALTER
Block Format Keyword An advanced nonlinear stress-based failure criteria for glass applications such as a windshield.
The failure stress is described by parameters defining micro-cracks and crack propagation speed. With the X-FEM approach, the stress is set to zero perpendicular to the crack direction.
| /FAIL/ALTER/mat_ID/unit_ID | |||||||||
| Exp_n | V0 | Vc | Ncycles | Irate | Iside | mode | |||
| Cr_foil | Cr_air | Cr_core | Cr_edge | grsh4N | grsh3N | ||||
| KIC | KTH | Rlen | Tdelay | Iout | |||||
| Kres1 | Kres2 | ||||||||
| Eta1 | Beta1 | Tau1 | Area_ref | ||||||
| Eta2 | Beta2 | Tau2 | |||||||
| Sig0 | P_scale | P_switch | |||||||
| fail_ID |
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit Identifier. (Integer, maximum 10 digits) |
| Exp_n | Crack growth exponent for subcritical
crack growth. Default = 16.0 (Real) |
| V0 | Crack growth velocity
for subcritical crack growth at
KIC. Default = 0.0 (Real) |
| Vc | Maximum crack propagation velocity
glass. Default = 0.0 (Real) |
| Ncycles | Stress filtering period in cycles. Only
used when Irate=0. 2
(Integer) |
| Irate | Stress rate filtering method.
(Integer) |
| Iside | Strain rate dependency option.
| mode | Flag to switch failure propagation
models between neighbor elements.
(Integer) |
| Cr_foil | Crack depth at bottom surface. Default = 0.0 (Real) |
| Cr_air | Crack depth at top surface. Default = 1.0 (Real) |
| Cr_core | Crack depth in between bottom and
surface integration points. Default = 1.0 (Real) |
| Cr_edge | Crack depth at the edge elements of
windshield. Default = 1.0 (Real) |
| grsh4N | (Optional) Group identifier for 4 node
edge shell elements. Default = 0 (Integer) |
| grsh3N | (Optional) Group identifier for 3 node
| KIC | Fracture toughness. Default = 0.0 (Real) |
| KTH | Fatigue threshold. Default = 0.0 (Real) |
| Rlen | Reference length. Default = 1.0 (Real) |
| Tdelay | Relaxation time before removing
elements. Default = 0.0 (Real) |
| Iout | Activate exhaustive failure flag in
Engine output file.
(Integer) |
| Kres1 | Residual tensile stress scale factor in
first crack direction. Default = 0.0 (Real) |
| Kres2 | Residual tensile stress scale factor in
second crack direction. Default = 0.0 (Real) |
| Eta1 | Distribution parameters
on bottom surface. 10
(Real) |
| Beta1 | Distribution parameters
on bottom surface. 10 (Real) |
| Tau1 | Distribution parameters
| Area_ref | Reference element surface
area. (Real) |
| Eta2 | Distribution parameters
on top surface. 10 (Real) |
| Beta2 | Distribution parameters
| Tau2 | Distribution parameters
| Sig0 | Initial stress at glass
surface. (Real) |
| P_scale | Limits the definition interval of
selected distribution function. (Real, between 0.0 and 1.0) |
| P_switch | Distribution function interval:
| fail_ID | Failure criteria
identifier. 9 (Integer, maximum 10 digits) |
Example (Glass)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
/MAT/LAW36/72200103/1
Glass with linear hardening
# RHO_I
2.50E-9
# E NU Eps_p_max Eps_t Eps_m
70000.0 0.23 0 0 0
# N_funct F_smooth C_hard F_cut Eps_f
1 1 0 1650 0
# fct_IDp Fscale fct_IDE EInf CE
0 0 0 0 0
# fct_ID1 fct_ID2 fct_ID3 fct_ID4 fct_ID5
722001021
# Fscale_1 Fscale_2 Fscale_3 Fscale_4 Fscale_5
1000
# Eps_dot_1 Eps_dot_2 Eps_dot_3 Eps_dot_4 Eps_dot_5
0
/FAIL/ALTER/72200103/1
# EXP_N V0 VC NCYCLES IRATE ISIDE MODE
16.0 6.0 1520000 6 0 0 1
# CR_FOIL CR_AIR CR_CORE CR_EDGE GRSH4N GRSH3N
0.00040 0.00100 0.00500 0 0 0
# KIC KTH RLEN TDEL Iout
23.717 7.9057 1.0 0 0
# KRES1 KRES2
0 0
# ETA1 BETA1 TAU1 AREA_REF
0 0 0 0
# ETA2 BETA2 TAU2
0 0 0
# SIG0 P_SCALE P_SWITCH
0 0 0
/FUNCT/722001021
Function for glass
# X Y
0.0 500.0
1.0 550.0
#enddata
- This failure criteria is using the maximum stress as failure criterion. It is computed based on the strength of the material determined by initial cracks and the crack propagation velocity. Depending on mode switch flag, different failure propagation models between neighbor elements may be used.
- When
Irate=0, an exponential moving average filter is
used, and the filtered stress is:Where,
- This failure model is compatible only with under-integrated shell elements (Ishell =24 and Ish3n =2 are recommended) and not compatible with fully integrated shells. Also, although there is no restriction of the shell property that can be used, it is only compatible with one layer shell models.
- The elements defined in the groups grsh4N and grsh3N should be along the edge of the windshield and will receive specific failure weakening.
- This failure model is applied to shell
elements that sandwich a polyvinyl butyral (PVB) solid element layer using coincident
nodes. The entire assembly models a windshield.
Figure 1. Windshield finite element model
Figure 2. Windshield model - entire assembly
- The shell elements using this failure model should be oriented so that their normals point away the from the middle PVB.
- The shell elements should have an offset applied to correctly model bending. This can be done using /PROP/TYPE51 Ipos=4.
- The fracture limit depends on the location and the fracture state of surrounding elements. 1
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL and /PERTURB/FAIL/BIQUAD. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick and with /STATE/SHELL/FAIL for shell).
- Ch. Brokmann extension 2 defines additional fracture criteria for external glass
surfaces only. It introduces initial stress on the glass surface, due to mechanical or
chemical treatment. Statistical evaluation of micro flaws in the glass surface allows to
define a probability of fracture using left-truncated Weibull stochastic distribution:
with = 1,2 for bottom and top surface
Truncation point yields the well-known two-parameter Weibull distribution. The Brokmann model calculates the randomly oriented initial flaws in the glass and distributes them over all finite elements with different lengths and geometry. Crack growth may be expressed by the following differential equation:
Where, is a flaw geometry factor obtained using Weibull distribution.
Integral of Equation 3 will yield actual crack size, strongly dependent on stress rate. Actual stress intensity factors can be calculated and used in the fracture criteria.
The interest of Brokmann’s model is that depending on the distribution parameters and failure stress value, it is possible to estimate the stochastic probability of failure.Figure 3.
After running a sufficient number of simulations with random initialization of glass flaws return a possibility to estimate a probability to reach a given value of the head injury criterion (HIC).Figure 4.
- Flag Irate is automatically set to 0 when Ch. Brokmann criterion is used. It is then necessary to define the number of cycles for the stress filtering interval using exponential average.
