Tasker Health Checks
By default, the vovtasker does not perform many health checks. If the jobs can be executed successfully, that is normally enough of a check.
In some large farms, it may be useful to activate additional checks, by invoking the
tasker with the option -H
[PpDdWwUu], where
the lower case characters mean "disable" and the upper case characters mean "enable"
of a particular check.
Built-in Checks in vovtasker
Check Name | Char | Description |
DiskSpace | d | Check space in /tmp and /usr/tmp |
WritePerm | w | Check write permissions in /tmp and /usr/tmp |
Portmap | p | Check that the portmap daemon is responsive |
UserScript | u | Check by executing an adminstrator-created, installation-wide script (see below) |
-H
in vovtasker, as in the following example, which activates only the
DiskSpace test:
% vovtasker -H Dwpu -a my_test_tasker
-health STRING
in a similar
way:## Fragment of taskers.tcl
vtk_tasker_define myHost -name my_test_tasker -health DWPU
User Created Script
- The script must be placed at $VOVDIR/local/tasker/health_user_script.csh
- The script should be secured appropriately to prevent unauthorized modification.
- The script will run as the user under which the project was started.
