Working point - If, I, Ψ, N
Positioning and objective
The aim of the test “Working point – Sine wave – Motor – If, I, Ψ, N” is to characterize the behavior of the machine when operating at the targeted input values If, I, Ψ, N (Magnitude of current, Magnitude of field current, Control angle, Speed).
Hence, these four inputs are enough to impose a precise working point.
The resulting model is fully parameterized, and it is built in Flux® environment, transient application.
| “Working point – Sine wave – Motor – If, I, Ψ, N” illustration |
The results of this test give an overview of the electromagnetic analysis of the machine considering its topology.
It also gives the capability to make comparisons between results obtained from the measurements and those with the FluxMotor®.
The following section describes all the user inputs to initialize the exported model.
All these parameters can be modified in Flux® environment, if needed.
