Basic model
Without scenario – Current source – Motor and generator – Basic model - Positioning and objective
This export allows the users to build a model in Flux® Skew, static application to perform magneto-static and multi-static simulations.
User inputs like, field current, line current, and control angle are predefined to get quick access into Flux® Skew environment for performing computations.
The resulting model is fully parameterized, and it is built in Flux® Skew environment, static application.
| Basic Model - Illustration |
The following section describes all the user inputs to initialize the exported model.
All these parameters can be modified in Flux® Skew environment, if needed.
