Inputs / Outputs
Specific inputs and outputs are considered for the pole topology.
The relevance of input parameter values can be evaluated by using the “Part Factory” application.
See the “Part Factory” application for more information.
Outputs are read only data. They complete the description of the topology.
| Inputs / Outputs of a pole | |
| 1 | The selection of a parameter label highlights it. |
| 2 | The selection of a parameter label displays the corresponding arrow on the picture. |
| 3 | The selection of a parameter label displays the corresponding tooltip which provides information about the parameter. |
