Operating conditions
Damper – Working point evaluation
The inter bar end ring impedances must be defined for a working point.
A table allows the user to describe a working point, defined by the temperature of the bars, and the two end rings.
| DAMPER – Definition of operating conditions for evaluating the end ring characteristic | |
| 1 | Definition of the temperatures (Bars and end rings) for which the impedances will be evaluated |
