BNDFREE
Bulk Data Entry Defines the degrees-of-freedom to be free during DMIG generation using CMSMETH card.
| BNDFREE | GID1 | IC1 | GID2 | IC2 | GID3 | IC3 |
| BNDFREE | 1220 | 12345 |
| GIDi | Grid of scalar point
identification numbers. No default (Integer > 0) |
| ICi | Component numbers. No default (Integer > 0) |
- BNDFREE and CSET are equivalent.
- ASET, BNDFIX and BNDFREE are not allowed in the same deck.
- If BNDFREE and ASET are present, the DOFs associated with ASET would be in BNDFIX; except the DOF assigned to BNDFREE.
- If BNDFIX and ASET are present, the DOFs associated with ASET would be in BNDFREE; except the DOF assigned to BNDFIX.
