DTABLE
Bulk Data Entry List of constants to be used in functions defined by DEQATN.
| DTABLE | LABL1 | VAL1 | LABL2 | VAL2 | LABL3 | VAL3 | LABL4 | VAL4 | |
| LABL5 | VAL5 | etc |
| DTABLE | W | 123.00 | H | 321.00 | B | 55.55 | AGE | 21 | |
| C | 36.0 | WST | 24.0 | HPS | 35.0 |
| LABLi | Constant
label. (Character) |
| VALi | Constant
value. (Real) |
- If a DTABLE entry has a pair of blank fields, they are ignored. If there are other constants after the blank fields, they are read in.
- If fields are full of zeros, the constant label is "0", and the value is 0.0.
- Multiple DTABLE entries are supported in the Bulk Data section.
- This card is represented as an optimization table entry in HyperMesh.
