MBCNTR
Bulk Data Entry Defines a Multibody contact between rigid bodies.
MBCNTR CID SID1 SID2 CNFTYPE PENAL COR MUSTAT MUDYN
CFFTYPE STVEL FTVEL
MBCNTR 2 4 7 POISSON 1E6 .5 .7 .3
COUL .1 .8
CID Contact identification number.
No default (Integer > 0)
SID1 Set identification number for a set of elements.
SID2 Set identification number for a set of elements.
No default (Integer > 0) (SID2 ≠ SID1)
CNFTYPE Contact normal force type.
Default = POISSON
PENAL Penalty factor.
Default = 1.0 (Real > 0.0)
COR Coefficient of restitution.
Default = 1.0 (0.0 ≤ Real ≤ 1.0)
MUSTAT Coefficient of static friction.
Default = 0.0 (Real ≥ 0.0)
MUDYN Coefficient of dynamic friction.
CFFTYPE Contact friction force type.
COUL (Default)
Activates the Coulomb Model of Friction, where the coefficient of friction used depends on the specified Stiction Transition Velocity (STVEL) and Friction Transition Velocity (FTVEL).
DYNA
Activates the Dynamic Friction model, where only the Dynamic Friction is active.
NONE
STVEL Stiction transition velocity. Defines the slip velocity at which the static coefficient of friction MUSTAT is applied.
FTVEL Friction transition velocity. Defines the slip velocity at which the dynamic coefficient of friction MUDYN is applied.
  1. This card is represented as a group in HyperMesh
