IPSADD
Bulk Data Entry Defines initial plastic strain condition for nonlinear static analysis as a union of INIPS entries.
IPSADD ID IS1 IS2 IS3 IS4 IS5 IS6 IS7
IS8 IS9 etc.
IPSADD 9 101 102 103
ID Each IPSADD Bulk Data Entry must have a unique ID.
No default (Integer > 0)
IS(i) Identification number of INIPS entries. The IS(i) values must be unique.
  1. IPSADD and INIPS should not have the same ID.
  2. The IPSADD Bulk Data Entry is selected by the Subcase Information Entry INIPS.
