CMBUSHE
Bulk Data Entry Defines a bushing element without reference to a property entry.
| CMBUSHE | EID | G1 | G2 | X1, G3 | Y1 | Z1 | |||
| "K" | K1EID | K2EID | K3EID | K4EID | K5EID | K6EID | |||
| "B" | B1EID | B2EID | B3EID | B4EID | B5EID | B6EID | |||
| "P" | P1 | P2 | P3 | P4 | P5 | P6 |
| CMBUSHE | 4 | 1 | 2 | 1.0 | 0.0 | 0.0 | |||
| K | 100 | 100 | 100 | 1 | 1 | 1 | |||
| B | 1 | 1 | 1 | 1 | 1 | 1 | |||
| P | 0 | 0 | 0 | 0 | 0 | 0 |
| EID | Unique element
identification number. (Integer > 0) |
| G1 | Grid point identification
| G2 | Grid point identification
| G3 | Grid point identification
number to optionally supply X1,
Y1, and Z1 in conjunction
with G1. (Integer > 0) |
| X1, Y1, Z1 | Orientation vector of the
bushing. (Real) |
| K | Stiffness specifier. | |
| K1EID, K2EID, K3EID | Translational stiffness
MBVAR ID. Default = 0 (Integer ≥ 0 or blank) |
| K4EID, K5EID, K6EID | Rotational stiffness
| B | Damping specifier. | |
| B1EID, B2EID, B3EID | Translational damping
| B4EID, B5EID, B6EID | Rotational damping
| P | Preload specifier. | |
| P1, P2, P3 | Translational preload. | |
| P4, P5, P6 | Rotational preload. |
- This card is represented as a spring element in HyperMesh.
