MATS1
Bulk Data Entry Specifies strain-, rate-, and temperature-dependent material properties for use in applications involving nonlinear materials.
Attention: Valid for Implicit and Explicit Analysis
This entry is used if a MAT1 entry is specified with the same MID in a nonlinear subcase.
Format A (HR = 1 to 3)
MATS1 MID TID TYPE H YF HR LIMIT1
TYPSTRN TYPSTRT
Optional continuation lines for defining damage initiation and evolution criteria
DAMAGE DMGINI_ID DMGEVO_ID PFAIL
Optional continuation lines for Johnson-Cook hardening (for Explicit Dynamic Analysis only)
JHCOOK A B N C RSTRT
Optional continuation lines for Crushable Foam model (for Explicit Dynamic Analysis only)
CFOAM TSC
Optional continuation lines for Cowper-Symonds model (for Explicit Dynamic Analysis only)
CSYMONDS D p
Optional continuation lines for Johnson-Holmquist model (for Explicit Dynamic Analysis only):
JHOLMQ A B M N C RSTRT SMAX
T HEL PHEL D1 D2
K1 K2 K3 BETA
Example A (HR = 1, 2, 3)
MATS1 17 28 PLASTIC 0.0 1 1 2.0E04
Format B.1 (HR = 6: Kinematic Hardening (NLKIN), TYPKIN=PARAM)
Format B illustrates the syntax of the MATS1 entry for HR=6. Both NLKIN and NLISO continuation lines can be defined on the same MATS1 entry.
MATS1 MID HR
NLKIN TYPKIN NKIN
SIGY0 C1 G1 C2 G2 etc. TEMP
etc. etc. etc.
Format B.2 (HR = 6: Kinematic Hardening (NLKIN), TYPKIN=HALFCYCL)
MATS1 MID HR
NLKIN TYPKIN NKIN
SIG EPS TEMP
etc. etc. etc.
Format B.3 (HR = 6: Isotropic Hardening (NLISO), TYPISO=PARAM)
MATS1 MID HR
NLISO TYPISO NISO
SIGY0 Q B TEMP
etc. etc. etc. etc.
Format B.4 (HR = 6: Isotropic Hardening (NLISO), TYPISO=TABLE)
MATS1 MID HR
NLISO TYPISO NISO
SIG EPS TEMP
etc. etc. etc.
Example (HR = 6): Kinematic Hardening
TYPKIN=PARAM, NLKIN=10, Temperature-independent
MATS1 17 6
+ NLKIN PARAM 10
120.0 1000.0 10.0 2000.0 20.0 3000.0 30.0 4000.0
40.0 5000.0 50.0 6000.0 60.0 7000.0 70.0 8000.0
80.0 9000.0 90.0 10000.0 100.0
Example (HR = 6): Combined Hardening
TYPKIN=PARAM, NLKIN=2, Temperature-dependent
TYPISO=PARAM, NLISO=1, Temperature-dependent
MATS1 17 6
+ NLKIN PARAM 2
120.0 1000.0 10.0 2000.0 20.0 23.0
100.0 800.0 8.0 1800.0 18.0 27.0
80.0 600.0 6.0 1600.0 16.0 35.0
NLISO PARAM 1
100.0 70 5.0 23.0
120.0 80 6.0 27.0
80.0 60 4.0 35.0
TYPKIN=HALFCYCL, NLKIN=2, Temperature-dependent
MATS1 17 6
+ NLKIN HALFCYCL 2
120.0 0.0 23.0
125.0 0.01 23.0
130.0 0.03 23.0
80.0 0.0 35.0
86.0 0.01 35.0
92.0 0.03 35.0
MID Identification of a MAT1 entry.
Integer
Specifies an identification number for this material.
<String>
Specifies a user-defined string label for this material entry. 1
No default (Integer > 0 or <String>)
TID Identification of a TABLES1, TABLEST, TABLEG or TABLEMD entry. If H is given, this field must be blank. 3
Integer
This is supported for all the table entries listed above.
<String>
This is supported only for the TABLES1 entry.
blank
(Integer ≥ 0, <String> (only for TABLES1), or blank)
TYPE Material nonlinearity type.
PLASTIC (Default)
Elastoplastic material.
In an LGDISP Analysis, this activates large strain elastoplasticity.
blank
H Work hardening slope (slope of stress versus plastic strain) in units of stress. For elastic-perfectly plastic cases, H = 0.0. For more than a single slope in the plastic range, the stress-strain data must be supplied on a TABLES1 or TABLEG entry referenced by TID, and this field must be blank. 2
(Real)
YF Yield function criterion.
1
von Mises.
Supported only with Implicit Analysis (nonlinear static and nonlinear transient).
2
Maximum principal stress.
(Integer)
HR Hardening rule.
1 (Default)
Isotropic hardening.
2
Kinematic hardening.
3
Mixed hardening with 30% contribution of kinematic hardening and 70% contribution of isotropic hardening.
6
Combined hardening. 12
Adjustable mixed hardening is selected by choosing a (Real) value for HR:
0 < HR < 1
The contribution of the kinematic hardening is HR whereas the contribution of the isotropic hardening is 1 - HR. 6
(1, 2, 3, 6, or 0.0 < Real < 1.0) (Integer)
LIMIT1 Initial yield point.
The LIMIT1 field can be blank, if the initial yield point value is defined via a referenced TABLES1, TABLEG, TABLEST or TABLEMD entries on the TID field. OptiStruct will error out if LIMIT1 is blank and TID does not reference a TABLES1, TABLEG, TABLEST or TABLEMD entry.
(Real > 0 or blank)
TYPSTRN Specifies the type of strain used on the x-axis of the table pointed to by TID. The strain type is selected by one of the following values. 3, 5, 7, 10
0 (Default)
Total strain is used on the x-axis.
1
Plastic strain or volumetric strain is used on the x-axis. 10
(Integer)
TYPSTRT Specifies the type of strain rate used on the x-axis of the table pointed to by TID of TABLEMD. The strain rate type is selected by one of the following values. ,
0 (Default)
Total strain rate is used on the x-axis.
1
Plastic strain rate or volumetric strain rate is used on the x-axis.
(Integer)
CFOAM Flag that identifies that the Crushable Foam model parameters are to follow. 10
TSC Tensile stress cutoff. A nonzero, positive value is recommended for realistic behavior.
Default = 0.0 (Real ≥ 0.0)
JHCOOK Flag that identifies that the Johnson-Cook hardening method parameters are to follow. 9
A Material yield stress.
No default (Real)
B Coefficient to the plastic strain.
Default = 0.0 (Real)
N Exponent to the plastic strain.
Default = 1.0 (Real)
C Coefficient to the strain rate.
RSTRT Reference strain rate.
CSYMONDS Flag that identifies that the Cowper-Symonds method parameters are to follow. 11
D Cowper-Symonds strain rate parameter.
No default (Real)
p Cowper-Symonds strain rate parameter.
No default (Real)
JHOLMQ Flag that identifies that the Johnson-Holmquist model parameters are to follow. 18
A Intact normalized strength constant.
No default (Real)
B Fractured normalized strength constant.
No default (Real)
M Fractured strength pressure exponent.
No default (Real)
N Intact strength pressure exponent.
No default (Real)
C Strain rate coefficient.
No default (Real)
No default (Real)
[1/s]
SMAX Maximum normalized fractured strength.
No default (Real)
T Maximum pressure tensile strength.
No default (Real)
[Pa]
HEL Hugoniot elastic limit.
No default (Real)
[Pa]
PHEL Pressure at Hugoniot elastic limit.
No default (Real)
[Pa]
D1 Damage constant.
No default (Real)
D2 Damage exponent.
No default (Real)
K1 Bulk modulus.
No default (Real)
[Pa]
K2 Pressure coefficient.
No default (Real)
[Pa]
K3 Pressure coefficient.
No default (Real)
[Pa]
BETA Bulking pressure coefficient.
No default (0.0 < Real <1.0)
NLKIN Continuation line flag indicating that data input for kinematic hardening is to follow. 6, 13
TYPKIN Kinematic hardening data input type.
HALFCYCL (Default)
Table input providing stress-strain curve. Total stress from experiment is provided as a column via the SIG fields, while the Equivalent Plastic Strain column is provided via the EPS fields. For NLKIN, the equivalent plastic strain is usually sourced directly from the first cycle of the experiment.
If temperature-dependent data is to be provided, the final column is TEMP, which is the temperature. This column should be provided in ascending order.
PARAM
Parameter input which provides the parameters directly. The parameters are SIGY0, Ci, and Gi for kinematic hardening. These parameters can be temperature dependent via the TEMP column, which should be specified in an ascending order.
NKIN Number of back stresses for kinematic hardening definition via NLKIN.
Default = 1 (Integer)
NLISO Continuation line flag indicating that data input for isotropic hardening is to follow. 13
TYPISO Isotropic hardening data input type.
TABLE (Default)
Table input providing isotropic part of yield stress versus the equivalent plastic strain (similar to the curve used for isotropic hardening, HR=1). Isotropic part of the yield stress from experiment is provided as a column via the SIG fields, while the Equivalent Plastic Strain column is provided via the EPS fields. For NLISO, the equivalent plastic strain is usually sourced from cyclic loading experiments.
PARAM
Parameter input which provides the parameters directly. The parameters are SIGY0, Q, and B for isotropic hardening. These parameters can be temperature dependent via the TEMP column, which should be specified in an ascending order.
NISO Number of parameters for isotropic hardening definition via NLISO.
SIGY0 Initial yield stress via the PARAM option for NLKIN or NLISO.
No default (Real > 0.0)
Ci Parameter(s) Ci of back stress components for NLKIN (PARAM). Up to 10 parameters (C1 to C10) can be specified.
Gi Parameter(s) Gi of back stress components for NLKIN (PARAM). Up to 10 parameters (G1 to G10) can be specified.
Q Parameter Q for NLISO (PARAM).
B Parameter B for NLISO (PARAM).
SIG Stress input for data curve input for NLKIN (HALFCYCL) or NLISO (TABLE).
EPS Equivalent plastic strain input for data curve input for NLKIN (HALFCYCL) or NLISO (TABLE).
TEMP Temperature for temperature-dependent data specification for NLKIN or NLISO.
No default (Real)
DAMAGE Flag that identifies that the damage initiation and evolution criteria definition is to follow. 17
DMGINI_ID ID of the DMGINI Bulk Data Entry.
No default (Integer)
DMGEVO_ID ID of the DMGEVO Bulk Data Entry. This is optional.
Default = blank (Integer)
PFAIL Percentage of failed integration points prior to element deletion.
  • For shells: Percentage of failed integration in thickness.
  • For solids: Percentage of failed integration points.
Default = 1.0 (0 < Real < =1)
  1. String based labels allow for easier visual identification, including when being referenced by other entries (example, the MID field of properties). For more details, refer to String Label Based Input File.
  2. For elastoplastic materials, the elastic stress-strain matrix is computed from the MAT1 entry, and the isotropic plasticity theory is used to perform the plastic analysis.
    Either the table identification TID or the work hardening slope H may be specified, but not both.
  3. If TID is given, TABLES1, TABLEG , TABLEST or TABLEMD entries (Xi,Yi) of stress-strain data ( ε x,Yx) must conform to the following:
    Entity TYPE = PLASTIC
    Quadrant Plastic stress-strain curve must be defined in the first quadrant only.
    First point If TYPSTRN = 0,
    • First point must be at the origin (X1=0, Y1=0).
    • Second point (X2, Y2) must be the initial yield stress (Y2=LIMIT1) at initial yield strain (X2=LIMIT1/E).
    The slope of the line joining the origin to the initial yield stress must be equal to the value of E.
    If TYPSTRN=1,
    • First point (X1, Y1) is corresponding to initial yield stress (Y1=LIMIT1), with zero equivalent plastic strain (X1=0).
    Additional details The data points must be in ascending order.
    If TYPSTRN=1,
    • TID may reference a TABLEST entry.
    In this case, the above rules apply to all TABLES1 tables pointed to by TABLEST.
    • In case of small deformations, the true and the engineering stress-strain curves are almost the same,so either of them can be used in the table definition.
    • In case of large deformations, the true stress-strain curve should be used.
    • If the deformations exceed the values defined in the table, linear extrapolation is performed.
  4. When TID refers to TABLEMD, the following applies:
    Xi_j Implicit Analysis (NLSTAT/Nonlinear Transient Analysis for SMDISP/LGDISP) Explicit Analysis
    Xi_1 Equivalent plastic strain. This can be used for both rate-dependent and independent problems. Represents plastic or total strain in case of rate-independent problems.
    Xi_2 Represents plastic strain rate in case of rate-dependent problems.
    If only one value of X2 is specified, it is still rate independent.
    Represents plastic or total strain rate in case of rate-dependent problems.
    Xi_3 Temperature N/A
  5. Information about rate dependent plasticity:
    Entity Implicit Analysis (NLSTAT/Nonlinear Transient Analysis for SMDISP/LGDISP) Explicit Analysis
    Activation Rate dependent plasticity can be activated by specifying TABLEMD ID in the TID field. This uses a piecewise linear function. Rate dependent plasticity can be activated in several ways.
    • Specifying TABLEMD ID in TID field. This uses a piecewise linear function.
    • Johnson-Cook model (only when the strain rate is greater than RSTRT).
    • Crushable Foam model.
    • Cowper-Symonds model.
    Elements Solid elements only. Shell and solid elements.
    Temperature dependent rate dependent plasticity Supported. The temperature-dependence is defined by referencing a TABLEST entry via the TID field. Not supported.
    TABLEMD definition A maximum of 4 fields can be used in TABLEMD, which represent,
    • Yield stress
    • Equivalent plastic strain
    • Plastic strain rate
    • Temperature
    Currently, only experimental data can be used. A stress-strain curve at zero plastic strain rate must be provided.
    A maximum of three fields can be used in TABLEMD, which represent,
    • Yield stress
    • Plastic/total/volumetric strain rate
    Supported strain rates Only plastic strain rate is supported. Hence, total strain rate input (TYPSTRT=0) is ignored. Plastic/total/volumetric strain rate is supported.
    Additional remarks Total strain input (TYPSTRN=0) is not supported and ignored.
    The second column in TABLEMD must be the equivalent plastic strain.
    Mixed hardening (HR=1, 2, 3 or real value) can be combined with rate dependent plasticity (TID=TABLEMD).
  6. Support information for kinematic and mixed hardening:
    Supported Entity Implicit Analysis (NLSTAT and Nonlinear Transient Analysis) Explicit Analysis
    Elements
    SMDISP
    Shell (1st order) and solid elements
    LGDISP
    Shell (1st order) and Solid elements
  7. The conversion of the stress versus total strain (TYPSTRN=0) into stress versus plastic strain (TYPSTRN=1) is illustrated in Figure 1. This is clearly different than simply shifting the entire table along the epsilon-axis.
  8. Element support restrictions for MATS1:
    Element Type
    Restriction
    Second order shell elements (CTRIA6 and CQUAD8)
    • MATS1 is not supported
    CROD, CONROD, CBAR and CBEAM
    • MATS1 is supported in the axial translational direction only
    • The behaviors in other directions remain elastic. More specifically, the torsional deformation of the CROD/CONROD elements or the shear, bending and torsional deformations of the CBAR/CBEAM elements remain elastic.
  9. Information on the Johnson-Cook model:
    Entity
    Details
    Analysis type
    Supported only for Explicit Dynamic Analysis
    Strain rate dependency
    Activated only when strain rate is greater than reference strain rate
    Formulation:
    σ = ( a + b ε p n ) ( 1 + c ln ( ε ˙ ε ˙ 0 ) ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaey ypa0ZaaeWaaeaacaWGHbGaey4kaSIaamOyaiabew7aLnaaDaaaleaa caWGWbaabaGaamOBaaaaaOGaayjkaiaawMcaamaabmaabaGaaGymai abgUcaRiaadogaciGGSbGaaiOBamaabmaabaWaaSaaaeaacuaH1oqz gaGaaaqaaiqbew7aLzaacaWaaSbaaSqaaiaaicdaaeqaaaaaaOGaay jkaiaawMcaaaGaayjkaiaawMcaaaaa@4C99@
    σ ¯ = ( A + B ( ε ¯ p l ) n ) ( 1 + C ln ( ε ¯ ˙ p l ε ˙ 0 ) ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae bacqGH9aqpdaqadaqaaiaadgeacqGHRaWkcaWGcbWaaeWaaeaacuaH 1oqzgaqeamaaCaaaleqabaGaamiCaiaadYgaaaaakiaawIcacaGLPa aadaahaaWcbeqaaiaad6gaaaaakiaawIcacaGLPaaadaqadaqaaiaa igdacqGHRaWkcaWGdbGaciiBaiaac6gadaqadaqaamaalaaabaGafq yTduMbaeHbaiaadaahaaWcbeqaaiaadchacaWGSbaaaaGcbaGafqyT duMbaiaadaWgaaWcbaGaaGimaaqabaaaaaGccaGLOaGaayzkaaaaca GLOaGaayzkaaaaaa@514E@
    Johnson-Cook strain rate dependence assumes that
    σ ¯ = σ 0 ( ε ¯ p l , θ ) R ( ε ¯ ˙ p l ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae bacqGH9aqpcqaHdpWCdaahaaWcbeqaaiaaicdaaaGcdaqadaqaaiqb ew7aLzaaraWaaWbaaSqabeaacaWGWbGaamiBaaaakiaacYcacqaH4o qCaiaawIcacaGLPaaacaWGsbWaaeWaaeaacuaH1oqzgaqegaGaamaa CaaaleqabaGaamiCaiaadYgaaaaakiaawIcacaGLPaaaaaa@499B@
    and ε ¯ ˙ p l = ε ˙ 0 exp ( 1 C ( R − 1 ) ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbae HbaiaadaahaaWcbeqaaiaadchacaWGSbaaaOGaeyypa0JafqyTduMb aiaadaWgaaWcbaGaaGimaaqabaGcciGGLbGaaiiEaiaacchadaqada qaamaalaaabaGaaGymaaqaaiaadoeaaaWaaeWaaeaacaWGsbGaeyOe I0IaaGymaaGaayjkaiaawMcaaaGaayjkaiaawMcaaaaa@4780@ for σ ¯ ≥ σ 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae bacqGHLjYScqaHdpWCdaahaaWcbeqaaiaaicdaaaaaaa@3C42@ .
    Where,
    σ ¯ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae baaaa@37D2@
    Yield stress for non-zero strain rate
    ε ¯ p l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbae badaahaaWcbeqaaiaadchacaWGSbaaaaaa@39C9@
    Equivalent plastic strain rate
    ε ˙ 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbai aadaWgaaWcbaGaaGimaaqabaaaaa@388D@ and C MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qaaaa@36BF@
    Material parameters measured at or below the transition temperature θ t r a n s i t i o n MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiUde3aaS baaSqaaiaadshacaWGYbGaamyyaiaad6gacaWGZbGaamyAaiaadsha caWGPbGaam4Baiaad6gaaeqaaaaa@4156@
    σ 0 ( ε ¯ p l , θ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaW baaSqabeaacaaIWaaaaOWaaeWaaeaacuaH1oqzgaqeamaaCaaaleqa baGaamiCaiaadYgaaaGccaGGSaGaeqiUdehacaGLOaGaayzkaaaaaa@4076@
    Static yield stress
    R ( ε ¯ ˙ p l ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaabm aabaGafqyTduMbaeHbaiaadaahaaWcbeqaaiaadchacaWGSbaaaaGc caGLOaGaayzkaaaaaa@3C3B@
    Ratio of the yield stress at nonzero strain rate to the static yield stress R ( ε ˙ 0 ) = 1.0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaabm aabaGafqyTduMbaiaadaWgaaWcbaGaaGimaaqabaaakiaawIcacaGL PaaacqGH9aqpcaaIXaGaaiOlaiaaicdaaaa@3E24@
  10. Information on the Crushable Foam model:
    Entity
    Details
    Analysis type
    TSC definition
    Defined as a positive stress value which indicates the yield stress of crushable foam under tensile loading
    Table definition
    The yield stress of crushable foam under compression loading can be given by a rate independent table (TABLES1) where the following rules apply:
    • x values in the table are the volumetric strain (all positive values indicate that the volume is compressed). The volumetric strain is defined as γ = 1 − V V 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdCMaey ypa0JaaGymaiabgkHiTmaalaaabaGaamOvaaqaaiaadAfadaWgaaWc baGaaGimaaqabaaaaaaa@3CF7@ .
    • y values in the table are the compression yield stress (all positive values).
      Note: Since crushable foam is based on volumetric strain-based definition, TYPSTRN=0 (default) is invalid and TYPSTRN=1 must be specified.
    • First entry is x=0, y=y_0 (the initial compressive yield stress).
    • All xi should be positive and in increasing order.
    Specific output
    Instead of the equivalent plastic strain, the integrated volumetric strain result (natural logarithm of the relative volume − I n ( V V 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeyOeI0Iaam ysaiaad6gadaqadaqaamaalaaabaGaamOvaaqaaiaadAfadaWgaaWc baGaaGimaaqabaaaaaGccaGLOaGaayzkaaaaaa@3CE3@ is output.
  11. Information on the Cowper-Symonds model:
    Entity
    Details
    Analysis type
    TYPSTRT
    Either total strain rate or plastic strain rate can be used
    f ( ε p l ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaabm aabaGaeqyTdu2aaWbaaSqabeaacaWGWbGaamiBaaaaaOGaayjkaiaa wMcaaaaa@3C2E@
    Can be specified in linear hardening form or tabular form using TABLES1 or TABLEMD
    Formulation:
    The yield stress is computed as:
    σ y = β f ( ε p l ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMhaaeqaaOGaeyypa0JaeqOSdiMaamOzamaabmaabaGa eqyTdu2aaWbaaSqabeaacaWGWbGaamiBaaaaaOGaayjkaiaawMcaaa aa@41CC@
    Where,
    Reference rate plastic strain versus yield stress hardening function.
    β
    Strain rate effect term, computed as β = 1 + ( ε ˙ D ) 1 p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqOSdiMaey ypa0JaaGymaiabgUcaRmaabmaabaWaaSaaaeaacuaH1oqzgaGaaaqa aiaadseaaaaacaGLOaGaayzkaaWaaWbaaSqabeaadaWcaaqaaiaaig daaeaacaWGWbaaaaaaaaa@4039@ .
  12. Information on using combined hardening:
    Entity
    Details
    Analysis type
    Supported only for Implicit Analysis (Nonlinear Static and Transient for SMDISP/LGDISP)
    Element type
    Supported only for solid elements
    Rate dependent plasticity with combined hardening
    Not supported, thus TID field is ignored
    Flexibility in combination
    Both NLKIN and NLISO support either parameter or stress-strain curve input.
    They can be combined flexibly, for example NLKIN with parameter input (PARAM) and NLISO with stress-strain curve input (TABLE).
    At least one type of nonlinear hardening should be defined. For more information, refer to the Combined Hardening of von Mises Plasticity.
  13. Information on using NLKIN or NLISO:
    Entity
    Details
    Analysis type
    Supported only for Implicit Analysis (NLSTAT/Nonlinear Transient Analysis for SMDISP/LGDISP)
    Temperature dependency
    When TYPKIN = HALFCYCL or TYPISO = TABLE, multiple curves can be provided one after each other. The last column temperature (TEMP) should be in ascending order. When TYPKIN/TYPISO = PARAM, the parameters can be temperature dependent, with TEMP specified in ascending order.
    Parameter fitting (for TABLE/HALFCYCL)
    The Levenberg-Marquardt method is used.
    The parameters are printed in the .out file for each temperature.
    Equivalent plastic strain determination
    For NLKIN, it is usually sourced directly from the first cycle of the experiment. For NLISO, it is usually sourced from cyclic loading experiments.
    Additional remarks
    If both NLKIN and NLISO use PARAM format, then the initial yield stress SIGY0 should be the same for the same temperature.
    After the continuation line, an unlimited number of continuation lines can be added to the data block.
  14. When TYPKIN=PARAM, if the number of back stresses is equal to or greater than 4, multiple continuation lines can be used to define the complete set of parameters (C1-C10, G1-G10). See the example above.
  15. Temperature-dependent materials can be activated at the subcase level via different options (such as TEMP(MAT), TEMP(BOTH), DLOAD (via TLOAD1, TLOAD2 and TEMP/TEMPD Bulk Data Entries), etc.) depending on the subcase type.
  16. Temperature-dependent material can be activated at the subcase-level via different options (such as TEMP(MAT), TEMP(BOTH), DLOAD (via TLOAD# and TEMP/TEMPD Bulk Data Entries), and so on ...) depending on the subcase type. For more information, refer to Comment 2 on the TEMPERATURE Subcase Information Entry.
  17. The damage initiation and evolution failure criteria can be defined using two methods:
    • Using the DAMAGE continuation line in the MATS1 Bulk Data Entry. This method is supported both for Implicit and Explicit Dynamic Analysis.
    • Using CRI=INIEVO in the MATF Bulk Data Entry. This method is supported only for Explicit Dynamic Analysis.
    For more information, refer to Material Failure Criterion in the Explicit Dynamic Analysis section of the User Guide.
  18. The Johnson-Holmquist material model is available to model brittle material behavior. It can be used with MAT1 elastic behavior and is currently only supported for solid elements. The shear modulus ( G ) and bulk modulus ( K 1 ) can be used to input the corresponding Young's modulus and Poisson's ratio as:
    E = 9 K 1 G 3 K 1 + G ν = 3 K 1 - 2 G 6 K 1 + 2 G
    The equivalent stress is the normalized Von Mises stress:
    σ V M * = 1 σ H E L 3 2 σ x x 2 + σ y y 2 + σ z z 2 + 2 σ x y 2 + 2 σ y z 2 + 2 σ z x 2
    Where the normalizing stress is the Hugoniot elastic limit is calculated as:
    σ H E L = 3 2 H E L - P H E L
    The normalized Von Mises stress, σ V M * is compared to the normalized yield stress σ * obtained with:
    σ * = 1 - D σ i * + D σ f *
    Where,
    σ i *
    Intact material yield stress: σ i * = a P * + T * n 1 + c ln ε ˙ ε ˙ 0
    α f *
    Failed material yield stress: σ f * = b P * m 1 + c ln ε ˙ ε ˙ 0 < σ f m a x *
    Where,
    σ *   =   σ σ H E L MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbwvMCKfMBHbqee0evGueE0jxy aibaieYlf9irVeeu0dXdh9vqqj=hEeeu0xXdbba9frFj0=OqFfea0d Xdd9vqaq=JfrVkFHe9pgea0dXdar=Jb9hs0dXdbPYxe9vr0=vr0=vq pWqaaeaabiGaciaacaqabeaabiWacqaaaOqaaiabeo8aZjaacQcaca aMc8Uaeyypa0JaaGPaVpaalaaabaGaeq4WdmhabaGaeq4Wdm3aaSba aSqaaiaadIeacaWGfbGaamitaaqabaaaaaaa@414C@
    P * = P P H E L
    T * = T P H E L
    If no damage parameters are specified ( D 1 = D 2 = 0 ) , no plastic strain evolution is computed and an instant failure is obtained when the element behavior reaches the elastic limit. Otherwise, when damage parameters are mentioned, the plastic strain evolution is computed and the accumulated damage is:
    D = ∑ Δ ε f p ε f p
    Where the plastic strain to failure is calculated as:
    ε f p = D 1 P * + T * D 2
    The maximum pressure tensile strength is decreased during damage as:
    P * = - 1 - D T *
    This allows a smoother transition between σ i * and σ f * during damage.
    Figure 2. Evolution of Normalized Yield Stress with Respect to Normalized Pressure. Damage value of D = 0.5.
    The pressure is computed following an equation of state defined as:
    P = K 1 μ
    in tension, and
    P = K 1 μ + K 2 μ 2 + K 3 μ 3
    in compression
    Where:
    μ = ρ ρ 0 - 1
    When damage starts, a bulking pressure increment Δ P is computed as a function of elastic energy loss Δ U converted into potential hydrostatic energy:
    Δ P t + Δ t = - K 1 μ + K 1 μ + Δ P t 2 + 2 β K 1 Δ U
    Where Δ U = U D - U D n + 1 , with U D = σ 6 G .
    This increment is then added to the equation of state described above:
    P t + Δ t = P t + Δ P t + Δ t
  19. When some nonlinear material models which are currently only supported for explicit analysis, such as Johnson-Cook, Crushable Foam, Cowper-Symonds, and Johnson-Holmquist materials, are used for implicit analysis subcases, only the linear elastic part of these materials is considered for implicit analysis. A corresponding WARNING message is also printed to the .out file.
