Move Implicit Geometry
Translate and rotate implicit bodies.
On the Implicit Modeling ribbon, select the
Move Bodies tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Optional: For Visualization Quality, select from Low to Very High quality, which corresponds to a low to very high density of elements. A higher quality produces sharper geometry features but is more computationally intensive. When creating a complicated function, it’s recommended to work using a lower quality and then switch to a higher quality after the function is complete.
Use the manipulators to translate and rotate the body.
