2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Ends automatic handle tracking and releases any handles acquired during handle tracking.
Gets a handle to the current session.
Gets a list of all active handles.
Begins automatic handle tracking.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hwi AutoStack
Tcl Modify
