Dual Motor Electric Powertrain
Architecture
The Dual Motor Powertrain is constructed utilizing Altair Twin Activate and is integrated into MotionView as a Functional Mock-up Unit (FMU). It consists of two motors, two inverters, a single battery pack, and a vehicle control unit (VCU) responsible for implementing regenerative braking and active torque distribution algorithms. The powertrain architecture in shown in the figure below.
Figure 1. Dual Motor Powertrain Architecture
Powertrain Architecture in Twin Activate
The Twin Activate architecture of the powertrain primarily divided into two main superblocks: the Dual Motor and the Vehicle Control Unit (VCU). The VCU is responsible for receiving input from the driver's throttle, as well as monitoring the vehicle's current state. It uses this information to make decisions regarding torque distribution within the vehicle and how each motor's torque should be utilized. The Dual Motor takes the outputs from the VCU and calculates the appropriate Pulse-Width Modulation (PWM) value to regulate the motor. It also determines the torque output for each motor, assesses the power demand, and finally, keeps track of the state of charge (SOC) level of the vehicle's battery.
Figure 2. Dual Motor Electric Powertrain with VCU Model in Twin Activate
Dual Motor Superblock
The Dual Motor superblock constits of two Permanent Magnet Synchronous Motors, two Voltage-Current controllers, two Inverter/Converters, and a Battery Pack.
Figure 3. Dual Motor Superblock in Twin Activate
A comprehensive model of the Permanent Magnet Synchronous Motor (PMSM) is established based on its speed-torque characteristics and efficiency data. This information is derived from an external efficiency map file (.efmp), which contains the torque-speed and torque-speed-efficiency characteristic curves of the motor. The data is explicitly obtained through Look-up Tables in the form of .mat files containing the relevant variables. This approach allows for the incorporation of user-defined electric motor data in vehicle simulations and ensures accurate calculation of power consumption.
The Torque-Speed characteristic curve is particularly significant as it delineates the torque boundaries for both the motor's tractive (positive) and regenerative braking (negative) regions, as shown in the figure below. These boundaries illustrate the maximum positive and negative torque that the motor can generate. The PMSM motor's characteristics encompass two distinct regions: a constant torque region and a constant power region. The motor can deliver its maximum torque up to its rated speed, and beyond that point, it can supply its maximum power.
Figure 4. Torque-Speed Characteristic Curve
The Torque-Speed-Efficiency curve, also known as efficiency map, is responsible for providing the efficiency values for each motor depending on its operating region. It also contains information for the motor’s traction and regenerative braking region as shown in the figure below.
Figure 5. Torque-Speed-Efficiency Characteristic Curve
Voltage-Current Motor Controllers
The Voltage-Current controller block is used to control the AC supplied to the motor. The control voltage depends on the vehicle speed, motor speed, accelerator pedal input and battery state of charge. To determine the appropriate voltage to apply to the motor, the controller employs Pulse Width Modulation (PWM) and references Torque lookup tables. Additionally, the voltage is subject to constraints imposed by the battery's state of charge (SOC). Notably, when the battery SOC exceeds 80%, the controller prohibits regenerative braking to safeguard the integrity of the battery cells, as such braking can potentially inflict damage. Conversely, if the battery SOC falls below 20%, the battery ceases to supply current, again as a protective measure for the battery cells.
A PWM Look Up table is used to calculate the PWM value using vehicle speed and accelerator pedal input. The PWM value ranges from 0 to 250. The value 50 is used for coasting i.e. at this value the motor will output 0 torque. If the PWM value is less than 50 the motor acts as a generator and is in regenerative mode. A PWM value greater than 50 means the motor is providing positive torque for traction.
Inverter/Converter Block
The inverter/converter blocks are responsible for modeling the power losses resulting from the frequency conversion process executed by the motor control. It stands in between the motor and the battery pack and provides the final power demand of each motor.
Battery Block
The Battery model receives as input the combined power demand from both motors as input. It contains the required information to determine the capacity of the battery pack. It specifies the charging/discharging losses from the vehicle operation, to estimate the battery’s state of charge.
Vehicle Control Unit Superblock
The Vehicle Control Unit block consists of the Torque Demand Estimation, the Torque Distribution Algorithm, and the Torque Ratio Calculation.
Figure 6. 1D Representation of the Vehicle Control Unit’block in Twin Activate
Torque Demand Estimator Block
The torque demand estimator defines the coasting region and regenerative braking using One-Pedal Driving 1 to estimate the combined motor torque demand. The coasting region consists of two distinct boundaries, as illustrated in the accompanying image.
Figure 7. Upper and Lower coasting boundaries vs different vehicle velocities for throttle pedal mapping
In the figure above, the region above pcu, is the tractive region and the region below the lower boundary (pcl) is the regenerative region. The coasting band between these boundaries increases with vehicle speed. This expansion is a deliberate design choice aimed at reducing the sensitivity of the accelerator pedal at higher vehicle speeds. The regenerative torque in the powertrain can be used to brake the vehicle in normal traffic conditions. The motor provides enough negative torque to operate the vehicle with only one pedal in case of city drives 1. At higher vehicle velocities, the regenerative torque alone is not sufficient to stop the vehicle and hence the friction braking should be used. The regenerative torque percentage in this model changes with vehicle velocity as shown in the figure below.
Figure 8. Regenerative Torque percentage of motor’s available torque vs vehicle speed
To achieve standstill condition in case of fully released accelerator pedal, the regenerative torque is set to 0 at 0 vehicle speed. This is done by setting the value of the first cell in PWM lookup table to 50 which means coasting.
Torque Distribution Algorithm Block
Four different torque distribution strategies are available focused on battery consumption reduction:
  1. Evenly Distributed (ED): a fixed 50-50% torque distribution is considered up to the point it cannot provide sufficient torque. When this limit is reached and additional torque is required, the system utilizes the remaining torque capacity of the motor with higher torque capabilities. Relies solely on motors’ maximum torque information (torque curve).
  2. Single Axle (SA): or overflow method – The torque is requested from a single motor while that motor can provide the entire torque. If a single motor cannot provide the torque, the residual is provided by the second motor – the torque request overflows to the second motor. Uses only motors’ maximum torque information (torque curve).
  3. Switch Threshold (ST): Calculates power losses online, based on provided motors’ efficiency maps and switches between ‘SA’ and ‘ED’ to reduce power consumption 2, 3.
    P l o s s S A = T d e m ⋅ ω ⋅ 1 η S A + e r − 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGtbGaamyqaaWdaeqaaaWcbeaak8qacqGH9aqpca WGubWdamaaBaaaleaapeGaamizaiaadwgacaWGTbaapaqabaGccqGH flY1peGaeqyYdCNaeyyXIC9aaeWaaeaadaWcaaqaaiaaigdaaeaacq aH3oaApaWaaSbaaSqaa8qacaWGtbGaamyqaaWdaeqaaOWdbiabgUca RiaadwgapaWaaSbaaSqaa8qacaWGYbaapaqabaaaaOWdbiabgkHiTi aaigdaaiaawIcacaGLPaaaaaa@5386@
    P l o s s E D = 1 2   T d e m ⋅ ω ⋅   1 η E D f +   e r − 1   +   1 2   T d e m ⋅ ω ⋅   1 η E D r +   e r − 1     1 η E D r +   e r − 1   MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGfbGaamiraaWdaeqaaaWcbeaak8qacqGH9aqpda WcaaWdaeaapeGaaGymaaWdaeaapeGaaGOmaaaacaGGGcGaamiva8aa daWgaaWcbaWdbiaadsgacaWGLbGaamyBaaWdaeqaaOGaeyyXIC9dbi abeM8a3jabgwSixpaabmaapaqaa8qacaGGGcWaaSaaa8aabaWdbiaa igdaa8aabaWdbiabeE7aO9aadaWgaaWcbaWdbiaadweacaWGebWdam aaBaaameaapeGaamOzaaWdaeqaaaWcbeaak8qacqGHRaWkcaGGGcGa amyza8aadaWgaaWcbaWdbiaadkhaa8aabeaaaaGcpeGaeyOeI0IaaG ymaiaacckaaiaawIcacaGLPaaacqGHRaWkcaGGGcWaaSaaa8aabaWd biaaigdaa8aabaWdbiaaikdaaaGaaiiOaiaadsfapaWaaSbaaSqaa8 qacaWGKbGaamyzaiaad2gaa8aabeaakiabgwSix=qacqaHjpWDcqGH flY1caGGGcWaaeWaa8aabaWdbmaalaaapaqaa8qacaaIXaaapaqaa8 qacqaH3oaApaWaaSbaaSqaa8qacaWGfbGaamira8aadaWgaaadbaWd biaadkhaa8aabeaaaSqabaGcpeGaey4kaSIaaiiOaiaadwgapaWaaS baaSqaa8qacaWGYbaapaqabaaaaOWdbiabgkHiTiaaigdacaGGGcaa caGLOaGaayzkaaWaaeWaa8aabaWdbiaacckadaWcaaWdaeaapeGaaG ymaaWdaeaapeGaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWa aSbaaWqaa8qacaWGYbaapaqabaaaleqaaOWdbiabgUcaRiaacckaca WGLbWdamaaBaaaleaapeGaamOCaaWdaeqaaaaak8qacqGHsislcaaI XaGaaiiOaaGaayjkaiaawMcaaaaa@8AC0@
    Where,
    • ω MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4DaiabeM8a3baa@38D2@ : motor speed
    • T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiva8aadaWgaaWcbaWdbiaadsgacaWGLbGaamyBaaWdaeqaaaaa @3A01@ : torque demand
    • P l o s s S A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGtbGaamyqaaWdaeqaaaWcbeaaaaa@3D02@ : power losses originating from single (rear) motor operation
    • P l o s s E D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGfbGaamiraaWdaeqaaaWcbeaaaaa@3CF7@ : power losses originating from dual motor 50-50 torque distribution operation
    • η S A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaam4uaiaadgeaa8aabeaaaaa@39AD@ : rear motor efficiency η S A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaam4uaiaadgeaa8aabeaaaaa@39AD@ = η S A w ,   T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaam4uaiaadgeaa8aabeaak8qadaqa daWdaeaapeGaam4DaiaacYcacaGGGcGaamiva8aadaWgaaWcbaWdbi aadsgacaWGLbGaamyBaaWdaeqaaaGcpeGaayjkaiaawMcaaaaa@4251@ , determined by motor's characteristic efficiency map
    • η E D f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGMbaapaqabaaaleqaaaaa@3AE4@ : front motor's efficiency η E D f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGMbaapaqabaaaleqaaaaa@3AE4@ = η E D f w ,   0.5 T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGMbaapaqabaaaleqaaOWdbmaabmaapaqaa8qacaWG3bGaaiilai aacckacaaIWaGaaiOlaiaaiwdacaWGubWdamaaBaaaleaapeGaamiz aiaadwgacaWGTbaapaqabaaak8qacaGLOaGaayzkaaaaaa@45B3@ , determined by motor's characteristic efficiency map
    • η E D r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGYbaapaqabaaaleqaaaaa@3AF0@ : rear motor's efficiency η E D r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGYbaapaqabaaaleqaaaaa@3AF0@ = η E D r w ,   0.5 T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamyraiaadseapaWaaSbaaWqaa8qa caWGYbaapaqabaaaleqaaOWdbmaabmaapaqaa8qacaWG3bGaaiilai aacckacaaIWaGaaiOlaiaaiwdacaWGubWdamaaBaaaleaapeGaamiz aiaadwgacaWGTbaapaqabaaak8qacaGLOaGaayzkaaaaaa@45BF@ , determined by motor's characteristic efficiency map
    • e r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamyza8aadaWgaaWcbaWdbiaadkhaa8aabeaaaaa@3844@ : small number to avoid division by zero
    Algorithm
    At every time step:
    1. Calculate both P l o s s S A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGtbGaamyqaaWdaeqaaaWcbeaaaaa@3D02@ , P l o s s E D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGfbGaamiraaWdaeqaaaWcbeaaaaa@3CF7@
    2. If P l o s s S A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGtbGaamyqaaWdaeqaaaWcbeaaaaa@3D02@ < P l o s s E D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadYgacaWGVbGaam4CaiaadohapaWa aSbaaWqaa8qacaWGfbGaamiraaWdaeqaaaWcbeaaaaa@3CF7@ set torque bias = 1
      Else: set torque bias = 0.5
  4. Optimal Torque Ratio (OTR): Offline exhaustive search method to determine optimal torque distribution for all torque-speed scenarios within motors’ capabilities 4. An optimal torque map is formed in advance, automatically utilizing the motors’ torque limits and efficiency data. Total electric power consumption is minimized by targeting each motor’s most efficient operating point. It is then used as a Look-up Table to select the most efficient torque split ratio in the range 0-100%.
    The method considers all possible combinations of motor angular speeds and torques within the range of each motors’ capabilities, which are defined by the .efmp files. Then, calculates the overall system efficiency using the following equation, for every possible torque split ratio. Outside of motors’ torque- speed range, the map provides the torque ratio that leads to maximum combined torque. Finally, the torque split ratio that results in optimum efficiency is selected, thus forming the optimal torque ratio map.
    η s y s   =   1 − r   T d e m   ω f   +   r   T d e m   ω r   1 − r   T d e m   ω f η f ω ,     1 − r   T d e m   +   e r + r   T d e m   ω r η r ω ,     r   T d e m +   e r + e r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaam4CaiaadMhacaWGZbaapaqabaGc peGaaiiOaiabg2da9iaacckadaWcaaWdaeaapeWaaeWaa8aabaWdbi aaigdacqGHsislcaWGYbaacaGLOaGaayzkaaGaaiiOaiaadsfapaWa aSbaaSqaa8qacaWGKbGaamyzaiaad2gaa8aabeaak8qacaGGGcGaeq yYdC3damaaBaaaleaapeGaamOzaaWdaeqaaOWdbiaacckacqGHRaWk caGGGcGaamOCaiaacckacaWGubWdamaaBaaaleaapeGaamizaiaadw gacaWGTbaapaqabaGcpeGaaiiOaiabeM8a39aadaWgaaWcbaWdbiaa dkhaa8aabeaak8qacaGGGcaapaqaa8qadaWcaaWdaeaapeWaaeWaa8 aabaWdbiaaigdacqGHsislcaWGYbaacaGLOaGaayzkaaGaaiiOaiaa dsfapaWaaSbaaSqaa8qacaWGKbGaamyzaiaad2gaa8aabeaak8qaca GGGcGaeqyYdC3damaaBaaaleaapeGaamOzaaWdaeqaaaGcbaWdbiab eE7aO9aadaWgaaWcbaWdbiaadAgaa8aabeaak8qadaqadaWdaeaape GaeqyYdCNaaiilaiaacckacaGGGcWaaeWaa8aabaWdbiaaigdacqGH sislcaWGYbaacaGLOaGaayzkaaGaaiiOaiaadsfapaWaaSbaaSqaa8 qacaWGKbGaamyzaiaad2gaa8aabeaaaOWdbiaawIcacaGLPaaacaGG GcGaey4kaSIaaiiOaiaadwgapaWaaSbaaSqaa8qacaWGYbaapaqaba aaaOWdbiabgUcaRmaalaaapaqaa8qacaWGYbGaaiiOaiaadsfapaWa aSbaaSqaa8qacaWGKbGaamyzaiaad2gaa8aabeaak8qacaGGGcGaeq yYdC3damaaBaaaleaapeGaamOCaaWdaeqaaaGcbaWdbiabeE7aO9aa daWgaaWcbaWdbiaadkhaa8aabeaak8qadaqadaWdaeaapeGaeqyYdC NaaiilaiaacckacaGGGcGaamOCaiaacckacaWGubWdamaaBaaaleaa peGaamizaiaadwgacaWGTbaapaqabaaak8qacaGLOaGaayzkaaGaey 4kaSIaaiiOaiaadwgapaWaaSbaaSqaa8qacaWGYbaapaqabaaaaOWd biabgUcaRiaadwgapaWaaSbaaSqaa8qacaWGYbaapaqabaaaaaaa@A48A@
    Where,
    • r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamOCaaaa@3700@ : torque split ratio
    • T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiva8aadaWgaaWcbaWdbiaadsgacaWGLbGaamyBaaWdaeqaaaaa @3A01@ : combined torque demand on both motors
    • ω f , r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaeqyYdC3damaaBaaaleaapeGaamOzaiaacYcacaWGYbaapaqabaaa aa@3AC2@ : front/ rear axle’s angular velocity, assumed equal
    • η f , r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4TdG2damaaBaaaleaapeGaamOzaiaacYcacaWGYbaapaqabaaa aa@3AA1@ : front/ rear motor’s efficiency as a function of ω MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaeqyYdChaaa@37D6@ , r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamOCaaaa@3700@ , T d e m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiva8aadaWgaaWcbaWdbiaadsgacaWGLbGaamyBaaWdaeqaaaaa @3A01@
      Calculated in python, by interpolating motor’s efficiency map
    • e r MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamyza8aadaWgaaWcbaWdbiaadkhaa8aabeaaaaa@3844@ : small number used to handle arithmetical errors, such as division by zero
    The figure below shows the 3D map that contains the optimal torque ratios for the default motor configuration. It is generated automatically before every simulation based on the motors’ provided data by the .efmp files.
    Figure 9. Optimal torque map, specified by the Optimal Torque Ratio strategy
Torque Ratio Calculation Block
Determines the final motor’s torque ratio considering parameters such as motors’ capabilities and vehicle’s state (tractive or regenerative braking). The motor’s torque ratio, as opposed to torque split ratio, is the percentage of motor’s torque utilization that is determined by the VCU and is indited by the following equation:
t r m = T m Τ m max ω MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiDa8aadaWgaaWcbaWdbiaadkhapaWaaSbaaWqaa8qacaWGTbaa paqabaaaleqaaOWdbiabg2da9maalaaapaqaa8qacaWGubWdamaaBa aaleaapeGaamyBaaWdaeqaaaGcbaWdbiabfs6au9aadaWgaaWcbaWd biaad2gapaWaaSbaaWqaa8qacaWGTbGaamyyaiaadIhaa8aabeaaaS qabaGcpeWaaeWaa8aabaWdbiabeM8a3bGaayjkaiaawMcaaaaaaaa@46B7@
Where,
  • T m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiva8aadaWgaaWcbaWdbiaad2gaa8aabeaaaaa@382E@ : motor's torque
  • Τ m m a x ω MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaeuiPdq1damaaBaaaleaapeGaamyBa8aadaWgaaadbaWdbiaad2ga caWGHbGaamiEaaWdaeqaaaWcbeaak8qadaqadaWdaeaapeGaeqyYdC hacaGLOaGaayzkaaaaaa@3F96@ : motor’s maximum torque as a function of speed
The torque ratio can receive values in the range of [-100, 100], where positive values depict motor operation in tractive mode and negative values regenerative braking mode.
Note: The complete Twin Activate diagram of the powertrain model can be accessed from: <install_dir>\ hwdesktop\hw\mdl\mdllib\Common\FMU_Library\Motor\FMU_source\Activate_Models.
Powertrain Model in MotionView
In the MotionView MDL system, the motors, inverters, and battery are represented as rigid bodies including their mass and inertia properties, which are a significant portion of BEV’s total mass and inertia. Two forces under Gearbox systems represent the driving torques attached to the driveshaft. Four Solver variables connect the FMU channels to the Altair Driver. Datasets contain crucial information on motor bodies’ properties. Moreover, each motor’s bushings are provided, that define the positions where the motors are based. Finally, the Altair Driver uses a Feedback Controller for speed and acceleration control.
The figure below shows how Twin Activate FMU connects with MotionSolve to couple the dual motor powertrain in the vehicle model. It also illustrates MotionView's role in taking in the motor’s information and initializing the simulation.
Figure 10. Twin Activate FMU Coupling with MotionSolve
The powertrain system in MotionView consists of Dataset, Outputs, a Template, Solver Variables, an FMU entity, and four separate subsystems, Motor Front, Motor Rear, Gearbox Front and Gearbox Rear. If selected in the Assembly Wizard while creating a model, a Battery Pack system will be also available in the model.
Datasets
Motor Properties
The torque distribution algorithms found on the VCU, rely on real motor torque-speed-efficiency data provided by external efficiency map files (.efmp). These files are a representation of the motors’ Torque-Speed and Torque-Speed-Efficiency characteristic curves. The paths pointing to these files are received as inputs in the Motor Properties Dataset.
Template
Evaluate Motor Properties
It is responsible for the initialization of an internal script (MotorProperties.py) before every simulation, used to:
  • Read the Teimorbit format .efmp file.
  • Extract motor properties.
  • Generate .mat files specific to the .xml file and store them in the run folder.
  • Assign the correct .mat file paths/variables in the FMU parameters section.
  • And finally, execute – if selected - the OTR torque distribution strategy to generate the optimal torque ratio map.
Solver Variables
Entities Type Description Comments
Driver Throttle Output Attachment solver variable Throttle signal from driver 0-1
Driver Clutch Output Attachment solver variable Clutch signal from driver Not used in the model but required by the driver’s attachment
Driver Gear Output Attachment solver variable Gear signal from driver Not used in the model but required by the driver’s attachment
FMU Torque - rear/front Solver Variable Rear/ Front motor output torques N-mm
FMU Omega rear/front Solver Variable Rear/ Front motor output wheel velocities rad/s
Torque Ratio - rear/front Solver Variable Rear/Front motor speed torque utilization 0-100
Vehicle Longitudinal Velocity m/s Solver Variable Vehicle’s longitudinal velocity m/s
Battery SOC Solver Variable Battery’s State-Of-Charge 0 - 1
Combined battery power demand Solver Variable The combined battery power demand from both motors Watt
Combined motor torque demand Solver Variable The combined torque demand from both motors N-m
Predicted combined torque demand Solver Variable The combined motor torque demand predicted by the VCU N-m
Torque split - rear Solver Variable Rear-front torque distribution, where 100% represents rear-wheel drive and 0% signifies front-wheel drive. 0 - 100
FMU Entity
Represents the FMU of the Dual Motor Electric Powertrain with inputs, outputs, parameters, and solver settings. The inputs of the FMU powertrain can be customized and you are free to change the system, however some inputs and outputs need to be present to correctly simulate a driver event. The schematic below shows the necessary inputs and outputs of the FMU powertrain block. The powertrain receives throttle, transmission input shaft speed front and rear, vehicle speed and outputs torque.
Figure 11. Dual Electric Motor Powertrain with VCU Co-simulation in Twin Activate
FMU Inputs
Connections Description Units Comments
Motor speed rear Rear Gearbox input shaft speed rad/s
Motor speed front Front Gearbox input shaft speed rad/s
Throttle from driver The accelerator pedal’s input from driver 0 - 100 Unit conversion required from MV’s 0-1 to FMU’s 0-100
Vehicle speed Vehicle’s longitudinal velocity m/s Unit conversion required from MV’s mm/s to FMU’s m/s
FMU Outputs
Torque from rear motor The output torque from the rear motor N-m Unit conversion required from FMU’s N-m to MV’s N-mm
Motor speed rear output rear motor shaft speed rad/s
Traction Coast Regen State rear Integer value that shows the operating mode of the rear motor: -1 indicates that powertrain is in regenerative braking mode, 0 means it is operating in coasting band and a value of 1 indicates that the motor is operating in tractive region -1, 0, 1
PWM rear value It corresponds to the pulse width modulation value which can be converted to voltage applied to the rear motor 0-250
Power demand rear motor Power demand from rear motor to the battery Watt
Torque from front motor The output torque from front motor N-m Unit conversion required from FMU’s N-m to MV’s N-mm
Motor speed front output Front motor shaft speed rad/s
Traction Coast Regen State rear Integer value that shows the operating mode of front motor: -1 indicates that powertrain is in regenerative braking mode, 0 means it is operating in coasting band and a value of 1 indicates that the motor is operating in tractive region -1, 0, 1
PWM front value It corresponds to the pulse width modulation value which can be converted to voltage applied to the front motor 0 - 250
Power demand front motor Power demand from front motor to the battery Watt
Battery SOC The state of charge of the battery 0 - 1
Combined battery power demand The combined battery demand from both motors Watt
Combined Motor Torque Demand The combined torque demand from both motors N-m Unit conversion required from FMU’s N-m to MV’s N-mm
Rear motor efficiency Rear motor’s efficiency 0 - 1
Front motor efficiency Front motor’s efficiency 0 - 1
Rear torque spit Torque distribution, using rear motor as a reference point 0 - 100
Predicted combined torque demand The combined motor torque demand predicted by the VCU N-m Unit conversion required from FMU’s N-m to MV’s N-mm
Torque ratio rear Rear motor’s torque ratio 0 - 100
Torque ratio front Front motor’s torque ratio 0 - 100
FMU Parameters
Parameters Description Units
converter_efficiency Converter’s efficiency value
inverter_efficiency Inverter’s efficiency value
num_modules_pack_parallel Number of module packs in parallel
num_cells_per_module_parallel Number of cells per module in parallel
capacity_cell Cell’s capacity Amp-hours
battery_charging_losses Coefficient to determine battery charging losses while at recuperation region
nominal_voltage_cell Cell’s nominal voltage V
num_cells_per_module_series Number of cell rows per module
num_modules_pack_series Number of module packs rows
SOC_initial Initial State-Of-Charge level (%)
battery_discharging_losses Coefficient to determine battery discharging losses while at tractive region
emotor_efficiency_scale Parameter to enable efficiency scaling
max_pwm Maximum PWM value
pwm_zero_torque PWM value corresponding to 0 torque output
SOC_limit_high Upper limit for SOC
SOC_limit_low Lower limit for SOC
max_vehicle_speed Vehicle’s maximum velocity m/s
coast_m Polynomial degree to determine coasting region
coast_phi At what pedal value coasting is desired
coast_ch Range of coasting to define pcl and pcu values
max_pedal Maximum throttle value 0 - 100
traction_gamma Polynomial degree to define the correlation between throttle and torque ratio for the traction region
regen_psi Order of polynomial to define the correlation between throttle and torque ratio for the regenerative region
traction_max Percentage of maximum available torque N-m
pedal_0_regen_percent 1-4 These parameters define the percentage of regenerative braking contribution to total braking as a function of velocity. Specifically, you can specify the regenerative braking percentage to determine the three sections of Figure 8.
pedal_0_vx 1-4 These parameters specify the corresponding velocities at specific regenerative braking percentages. Specifically, they are used to define the velocity values that designate the three sections of Figure 8.
Path char
Warning: This parameter is automatically updated, it should not be manually modified.
Mat file path that contains both motor characteristics, such as rated and maximum speed, rated torque
Vcu_type Set VCU torque distribution strategy:
1: ED
2: SA
3: ST
4: OTR
matfilename - Rear Motor data mat file path
Path pointing to rear motor’s mat file. Appearing multiple times in the FMU.
matfilename - Front Motor data mat file path
Path pointing to front motor’s mat file. Appearing multiple times in the FMU.
matfilename - Optimal Torque ratio map mat file path
Path pointing to optimal torque ratio .mat file path.
matvarname
Warning: This parameter is fixed, it should not be altered.
Refers to the rear, front motor or optimal torque ratio map .mat files’ variable names, used for data extraction. It appears multiple times in the FMU.
Motor Front/Rear Systems
Includes the integrated motor-inverter unit.
Bodies
Motor/Engine - Represents the lumped mass and inertia of each motor in a non-operating condition. The motor’s output shaft is assumed to be hard coupled with gearbox input shaft and hence their speed is going to be the same. The motor’s shaft and its rotation are not modeled. Since the inertia of the rotating shaft is not modeled, this inertia can be added in other rotating elements in the driveline.
Motor Mounts
Motors are attached to chassis by four bushings. The mount locations must be provided on the attachment body by specifying the coordinates of the mounts and the orientation of the bushings specified using the vectors corresponding to each mount.
Solver Variables
FMU Torque Solver Variable Motor output torque from FMU N-mm
FMU Omega Solver Variable Motor output wheel velocity from FMU rad/s
Throttle input to motor 100 Solver Variable Throttle input from driver 0-100
FMU Power demand motor Solver Variable Motor power output W
Traction/Coast/Regen state Solver Variable Integer value that shows the operating mode of motor: -1 indicates that powertrain is in regenerative braking mode, 0 means it is operating in coasting band and a value of 1 indicates that the motor is operating in tractive region -1, 0, 1
PWM value Solver Variable It corresponds to the pulse width modulation value which can be converted to voltage applied to the rear motor 0-250
Motor Efficiency Solver Variable Motor’s efficiency 0-1
Gearbox Front/Rear Systems
Bodies
Gearbox – Contains the mass and inertia properties of gearbox body in a non-operating condition. Gearbox is also assumed to be directly attached to the motor body, with the usage of a fixed joint. The motor’s output shaft is assumed to be hard coupled with gearbox input shaft and hence their speed is going to be the same.
Datasets
Gearbox Data
Label Description
Final Drive Ratio Differential’s final stage of gear reduction ratio, used to calculate the final drive torque.
Gearbox Efficiency Gearbox’s overall efficiency, used to calculate the final drive torque.
Solver Variables
Torque from Gear Box Solver Variable Mathematical expression used to calculate gearbox’s final output torque. N-mm
Gear Box Input Shaft Speed Solver Variable Mathematical expression used to calculate gearbox’s input shaft speed. rad/s
Forces
Gearbox Output Torque - Represents the powertrain’s output torque on the differential’s carrier body. The torque is calculated by the ‘Torque from Gear Box’ Solver Variable expression.
Battery Pack
If the battery pack module has been selected from the Assembly Wizard, it can be found as a separate system, out of the primary Dual Motor Powertrain system. It includes:
Bodies
Battery Pack - Represents body's mass and inertia properties.
Battery Mounts
Battery is attached to chassis by four bushings. The mount locations must be provided on the attachment body by specifying the coordinates of the mounts and the orientation of the bushings specified using the vectors corresponding to each mount.
Access the Electric Powertrain for Full Vehicle Models
  1. The Vehicle Tools extension must be loaded.
    1. From the menu bar, select File > Extensions.
    2. Load the Vehicle Tools extension by sliding the Load button to the right.
      The Vehicle Tools ribbon is add in MotionView.
      Figure 12.
  2. In the Vehicle Tools ribbon, click the Assembly tool to open the Assembly Wizard.
  3. Select the Full Vehicle with Driver model and click Next.
    Figure 13. Select Model Type
  4. Choose the Four wheel drive driveline configuration and then select the Dual Motor Electric Powertrain (FMU), which is listed in the Powertrain drop-down menu.
    Figure 14.
  5. After selecting the vehicle’s powertrain type, you can also opt for a Battery Pack body.
    Figure 15.
After finishing the vehicle building process, a Full vehicle with Dual Electric Powertrain (FMU) is loaded in MotionView.
Figure 16. Four-wheel drive model with Dual Motor Electric Powertrain FMU
Modifying the FMU Powertrain
You can easily customize the default powertrain specifications to suit a specific requirement by adjusting parameters within the FMU's parameter section. Throttle response, regenerative braking contribution to total braking, and battery’s capacity are the main parameters that can be altered. The vehicle’s behavior parameterization is mainly divided into two main sections regarding motor specifications and regenerative braking.
Motor specifications are provided by external data, that are included in .efmp files and located in the Motor Properties dataset under the MotionView Model – Single Motor Electric Powertrain (FMU) system. The vehicle motor’s properties can be changed by manipulating the data inside the .efmp files. In addition, your own .efmp files containing motor characteristics can be included, as long as they are teimorbit format compliant. A sample of the .efmp file is illustrated below for reference.
$---------------------------------------------------------------------ALTAIR_HEADER
[ALTAIR_HEADER]
FILE_TYPE     =  'efmp'
FILE_VERSION  =  1.0
FILE_FORMAT   =  'ASCII'
$--------------------------------------------------------------------------UNITS
[UNITS]
(BASE)
{length  force      angle       mass    time}
'm'   'newton'   'degrees'   'kg'    'sec'
(USER)
{unit_type    length  force  angle  mass  time  conversion}
'rpm'          0       0      1      0     -1     6.0
'torque'       1       1      0      0      0     1.0
$-------------------------------------------------------------------------Motor Details
[EFFICIENCY_MAP]
(X_DATA)
{speed}
+0.000000E+00
+8.537861E+01
+3.415145E+02
+7.684075E+02
+1.366058E+03
+2.134465E+03
+3.073630E+03
+4.183552E+03
+5.728759E+03
+7.273966E+03
+8.819173E+03
+1.036438E+04
+1.190959E+04
+1.345479E+04
+1.500000E+04
$-------------------------------------------------------------------------Efficiency
(YZ_DATA)
{a b c d e f g h i j k l m n o p}
+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00	+0.000000E+00
+1.218756E+00	+0.000000E+00	+8.323871E-01	+8.348879E-01	+8.207778E-01	+7.975356E-01	+7.686840E-01	+7.357196E-01	+6.984794E-01	+6.564586E-01	+6.174752E-01	+5.872302E-01	+5.100155E-01	+4.613040E-01	+4.190096E-01	+3.827032E-01
+4.875026E+00	+0.000000E+00	+8.814608E-01	+9.318992E-01	+9.365690E-01	+9.319987E-01	+9.231622E-01	+9.104752E-01	+8.949006E-01	+8.728267E-01	+8.505602E-01	+8.328031E-01	+8.007164E-01	+7.678712E-01	+7.359362E-01	+7.055424E-01
+1.096881E+01	+0.000000E+00	+8.376550E-01	+9.363595E-01	+9.546854E-01	+9.582281E-01	+9.565427E-01	+9.522109E-01	+9.459273E-01	+9.365793E-01	+9.269542E-01	+9.121204E-01	+8.934734E-01	+8.735761E-01	+8.534340E-01	+8.334711E-01
+1.950010E+01	+0.000000E+00	+7.779298E-01	+9.228859E-01	+9.543095E-01	+9.639408E-01	+9.664942E-01	+9.656404E-01	+9.628304E-01	+9.575883E-01	+9.519336E-01	+9.419017E-01	+9.290871E-01	+9.152123E-01	+9.008979E-01	+8.863836E-01
+3.046891E+01	+0.000000E+00	+7.155875E-01	+9.027567E-01	+9.474120E-01	+9.628555E-01	+9.686488E-01	+9.702265E-01	+9.695124E-01	+9.667733E-01	+9.626870E-01	+9.544688E-01	+9.441605E-01	+9.329200E-01	+9.210782E-01	+9.086153E-01
+4.387523E+01	+0.000000E+00	+6.563856E-01	+8.792230E-01	+9.373423E-01	+9.584760E-01	+9.673843E-01	+9.709935E-01	+9.718605E-01	+9.707183E-01	+9.671191E-01	+9.594001E-01	+9.499134E-01	+9.392034E-01	+9.267406E-01	+9.036660E-01
+5.056248E+01	+0.000000E+00	+6.314770E-01	+8.682518E-01	+9.322428E-01	+9.559373E-01	+9.662057E-01	+9.706858E-01	+9.721578E-01	+9.716095E-01	+9.679095E-01	+9.601471E-01	+9.505474E-01	+9.390330E-01	+9.168608E-01	NaN
+5.919049E+01	+0.000000E+00	+6.030777E-01	+8.548915E-01	+9.257981E-01	+9.525703E-01	+9.644708E-01	+9.699594E-01	+9.721433E-01	+9.722637E-01	+9.681889E-01	+9.601339E-01	+9.496912E-01	+9.281723E-01	NaN	NaN
+7.075054E+01	+0.000000E+00	+5.703066E-01	+8.382680E-01	+9.174994E-01	+9.480588E-01	+9.619707E-01	+9.686980E-01	+9.717496E-01	+9.726024E-01	+9.676793E-01	+9.586062E-01	+9.380106E-01	NaN	NaN	NaN
+8.699840E+01	+0.000000E+00	+5.315730E-01	+8.168210E-01	+9.063657E-01	+9.418017E-01	+9.583267E-01	+9.666546E-01	+9.708084E-01	+9.720695E-01	+9.655065E-01	+9.453839E-01	NaN	NaN	NaN	NaN
+1.114960E+02	+0.000000E+00	+4.823827E-01	+7.864047E-01	+8.898433E-01	+9.321732E-01	+9.524598E-01	+9.630950E-01	+9.688285E-01	+9.694182E-01	+9.487760E-01	NaN	NaN	NaN	NaN	NaN
+1.540854E+02	+0.000000E+00	+4.040688E-01	+7.291549E-01	+8.564716E-01	+9.117700E-01	+9.393322E-01	+9.544374E-01	+9.631752E-01	+9.458014E-01	NaN	NaN	NaN	NaN	NaN	NaN
+2.104600E+02	+0.000000E+00	+3.119294E-01	+6.435543E-01	+8.010837E-01	+8.758160E-01	+9.149455E-01	+9.372630E-01	+9.507810E-01	NaN	NaN	NaN	NaN
$-------------------------------------------------------------------------ENGINE
[TORQUE_CURVE]
(DATA)
{speed torque}
+0.000000E+00	+2.104599E+02
+8.537861E+01	+2.104600E+02
+3.415145E+02	+2.104600E+02
+7.684075E+02	+2.104600E+02
+1.366058E+03	+2.104600E+02
+2.134465E+03	+2.104600E+02
+3.073630E+03	+2.104600E+02
+4.183552E+03	+2.104600E+02
+5.728759E+03	+1.540854E+02
+7.273966E+03	+1.114960E+02
+8.819173E+03	+8.699840E+01
+1.036438E+04	+7.075054E+01
+1.190959E+04	+5.919049E+01
+1.345479E+04	+5.056248E+01
+1.500000E+04	+4.387523E+01
+1.500000E+04	+0.000000E+00
Throttle response within the traction region is influenced by two key parameters: ‘ t r a c t i o n g a m m a MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiDaiaadkhacaWGHbGaam4yaiaadshacaWGPbGaam4Baiaad6ga paWaaSbaaSqaa8qacaWGNbGaamyyaiaad2gacaWGTbGaamyyaaWdae qaaaaa@428B@ ’ and ‘ t r a c t i o n m a x MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiDaiaadkhacaWGHbGaam4yaiaadshacaWGPbGaam4Baiaad6ga paWaaSbaaSqaa8qacaWGTbGaamyyaiaadIhaa8aabeaaaaa@40C4@ ’. The right setting should offer the correct balance between smoothness and responsiveness. Fine-tuning these settings can result in an improved driving experience by providing the desired balance between these two factors.
You can also determine the vehicle’s regenerative braking amount by handling the relevant parameters. The equations that determine the regenerative braking amount are derived by 1. Regenerative braking distribution is fixed by default to ’60-40’ front-rear. The traction, coasting and regeneration region for motor mapping are described in detail in 1. Vehicle’s coasting boundaries ‘ p c l MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiCaiaadogapaWaaSbaaSqaa8qacaWGSbaapaqabaaaaa@3931@ ’ and ‘ p c u MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiCaiaadogapaWaaSbaaSqaa8qacaWG1baapaqabaaaaa@393A@ ’ are defined by the parameters ‘ c o a s t m MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4yaiaad+gacaWGHbGaam4CaiaadshapaWaaSbaaSqaa8qacaWG Tbaapaqabaaaaa@3C08@ ’, ‘ c o a s t p h i MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4yaiaad+gacaWGHbGaam4CaiaadshapaWaaSbaaSqaa8qacaWG WbGaamiAaiaadMgaa8aabeaaaaa@3DE6@ ’, ‘ c o a s t c h MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4yaiaad+gacaWGHbGaam4CaiaadshapaWaaSbaaSqaa8qacaWG JbGaamiAaaWdaeqaaaaa@3CEB@ ’ and vehicle’s maximum velocity ‘ m a x   v e h i c l e   s p e e d MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamyBaiaadggacaWG4bGaaiiOaiaadAhacaWGLbGaamiAaiaadMga caWGJbGaamiBaiaadwgacaGGGcGaam4CaiaadchacaWGLbGaamyzai aadsgaaaa@4653@ ’. Vehicle’s regenerative amount for different speeds is determined by a map used as a Look-up table. ‘ p e d a l _ 0 _ r e g e n _ p e r c e n t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiCaiaadwgacaWGKbGaamyyaiaadYgacaGGFbGaaGimaiaac+fa caWGYbGaamyzaiaadEgacaWGLbGaamOBaiaac+facaWGWbGaamyzai aadkhacaWGJbGaamyzaiaad6gacaWG0baaaa@4949@ ’ and ‘ p e d a l _ 0 _ v x MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamiCaiaadwgacaWGKbGaamyyaiaadYgacaGGFbGaaGimaiaac+fa caWG2bGaamiEaaaa@3F20@ ’ are the parameters responsible for the speed – regenerative braking mapping. Finally, ‘ r e g e n p s i MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamOCaiaadwgacaWGNbGaamyzaiaad6gapaWaaSbaaSqaa8qacaWG WbGaam4CaiaadMgaa8aabeaaaaa@3DE8@ ’ is used to define the correlation between throttle and output torque.
Limitations
  • The rotational inertia of the motor’s shaft should be added in the rotating bodies in the driveline.
  • The default motor configuration assumes that the motor regenerative region is the same as tractive, in terms of efficiency mapping.
References
1 J. J. P. B. I. J. M. &. N. H. Van Boekel, "Design and realization of a One-Pedal-Driving algorithm for the TU/e Lupo EL," World Electric Vehicle Journal 7.2, pp. 226-237, 2015.
2 S. Salamone, "On the investigation of energy efficient torque distribution strategies through a comprehensive powertrain model," Sustainability 13.8, p. 4549, 2021.
3 X. a. J. W. Yuan, "Torque distribution strategy for a front-and rear-wheel-driven electric vehicle," IEEE Transactions on Vehicular Technology 61.8, pp. 3365-3374, 2012.
4 K. Cao, "All-wheel-drive torque distribution strategy for electric vehicle optimal efficiency considering tire slip.," EEE Access 9, pp. 25245-25257, 2021.
