Connect Member Panels and Members
If a panel or member has been created or edited, it may be necessary to connect or reconnect it.
From the Skeleton ribbon, click the Connect tool.
Select a connection option from the drop-down on the guide bar.
- Panel to Member
- Member to Member
- Panel to Panel
- Select the members/panels to connect.
Click
to define spring stiffness values.
These are applied to the PBUSH property, which is then subsequently associated to the CBUSH elements. -
On the guide bar, click one of the following:
- Apply and stay in the tool
- Apply and close the tool
- Exit the tool without applying
