Combine Members
Use the Combine tool to merge continuous members.
From the Skeleton ribbon, click the Combine tool.
Note: The Equivalence tool is grouped with the Equivalence/Duplicates tools. Click the arrow next to the tool to choose which is active on the ribbon. -
Click
on the guide bar to define options the break angle.
This is the max angular deviation that is considered a straight member. - Select members to consider.
- Click Find to locate continuous members within the given break angle.
- Optional:
Click
or
to review each instance.
- Click Merge All.
