Find Equivalent Joints
Use the Equivalence tool to consolidate overlapping joints within a given tolerance.
From the Skeleton ribbon, click the Equivalence
tool.
Note: The Equivalence tool is grouped with the Combine/Duplicates tools. Click the arrow next to the tool to choose which is active on the ribbon. -
Click
on the guide bar to define options.
- Allow member destruction
- A member of smaller or equal length to the minimum defined length is destroyed so that two member joints are merged together.
- Create offset legs
- Six members can be joined by a joint with each leg having an offset.
- Tolerance
- Used to search for nearby joints.
- Min length
- Small members below this value are destroyed.
- Select members to consider.
- Click Find to locate overlapping joints within the given tolerance.
- Optional:
Click
or
to review each instance.
- Click Merge.
