Browse Content and Files
To view contents in the ブラウザ:
- Select the Personal repository.
Select your desired library.
The contents of that library can now be queried for and display in the ブラウザ.注: If the selected library has a default saved query, that query will be executed when the library is opened. This might result in some contents not being visible in the ブラウザ.
- オプション: To view desired contents in the library, open the Query toolbar, clear any active queries, and run the desired query.
