Modify References
Use the Advanced Edit dialog to modify attributes, documents, and references to the selected, checked out content.
- Select Advanced Edit from コンテキストメニュー of a checked out content.
To modify references, click the Show/Hide Query icon to
query for contents in the Edit dialog.
You can use the associated Properties, Find, and Filter tools to help locate the content or contents you want to reference.
- Click Check-In to immediately check-in the checked-out content, capturing the changes and creating a new version.
- オプション:
Click Close to close the dialog and leave the content
checked-out.
Modifications made to the content in the Advanced Edit dialog take effect immediately. To undo changes, perform an Undo Check-Out.
