In this step, a modal method is used to solve the complex eigenvalue problem, which is more
computationally efficient compared to extracting the complex modes directly. With this
approach, first, the real modes are calculated via a normal modes analysis. Then, a
complex eigenvalue problem is formed on the projected subspace spanned by the real modes
which is much smaller than the real space. Here, both EIGRL and
EIGC cards need to be defined.
In the Model Browser, right-click and select Create > Load Step Inputs.
In the Name field, enter modal_space.
For Config type, select Real Eigen Value
Extraction.
For Type, select EIGRL from the drop-down menu.
Click V2 and input 5000.
5000 is defined as the highest frequency bond.
Click ND and input 100.
100 real modes are required to produce the reduced space for complex
eigenvalue analysis.
Create another load step input named ceig_squeal.
For Config type, select Complex Eigen Value
Extraction.
For Type, verify the default EIGC is selected.
Click NORM and select MAX.
MAX option is used to normalize the eigenvectors.
For ND0 OPTIONS, select User Defined from the drop-down
menu.
Click ND0 and input 55.
The desired number of roots to be extracted is 55.
モーダル複素固有値解析の荷重ステップの定義
Model Browser内で右クリックし、Create > Load Stepを選択します。
Name欄にBRSQと入力します。
Analysis typeをクリックし、ドロップダウンメニューからComplex eigen
(modal)を選択します。
