/SENSOR/DIST_SURF
Block Format Keyword Describes the sensors used to activate or deactivate an object according to the shortest distance from a reference node to a plane or a surface.
| /SENSOR/DIST_SURF/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| node_ID | Node_1 | Node_2 | Node_3 | ||||||
| Dmin | Dmax | Tmin | |||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| node_ID | Reference node
identifier. (Integer) |
| Node_1 | First node for the
plane surface definition. (Integer) |
| Node_2 | Second node for the
| Node_3 | Third node for the
| Dmin | Distance
minimum. Default = -1E30 (Real) |
| Dmax | Distance
maximum. Default = 1E30 (Real) |
| Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type DIST_SURF, the sensor is activated when distance or during Tmin value.
