/SENSOR/HIC
Block Format Keyword Describes the sensors used to activate or deactivate an object according to Head Injury Criteria (HIC).
/SENSOR/HIC/sens_ID/unit_ID
sens_title
Tdelay
accel_ID DIR
Period Value Gravity Tmin
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
accel_ID Accelerometer identifier.
(Integer)
gauge_ID Gauge identifier.
(Integer)
DIR Force direction.
=R (Default)
Resultant
=X
X direction
=Y
Y direction
=Z
Z direction
(Integer)
Period Time window for the HIC.
Default = 0.036, [ s ] if in SI unit (Real)
[ s ]
Value HIC limit value.
Default = 1E20 (Real)
[ s ]
Gravity Time window for the HIC.
Default = 9.80665 [ m s 2 ] if in SI unit (Real)
[ m s 2 ]
Tmin Minimum time duration before activation when criteria is reached. 3
(Real)
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type HIC, criteria is computed with:
    H I C P e r i o d = max { ( t 2 − t 1 ) [ 1 t 2 − t 1 ∫ t 1 t 2 a ( t ) . d t ] 5 2 } MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamisaiaadM eacaWGdbWaaSbaaSqaaiaadcfacaWGLbGaamOCaiaadMgacaWGVbGa amizaaqabaGccqGH9aqpciGGTbGaaiyyaiaacIhadaGadaqaaiaacI cacaWG0bWaaSbaaSqaaiaaikdaaeqaaOGaeyOeI0IaamiDamaaBaaa leaacaaIXaaabeaakiaacMcadaWadaqaamaalaaabaGaaGymaaqaai aadshadaWgaaWcbaGaaGOmaaqabaGccqGHsislcaWG0bWaaSbaaSqa aiaaigdaaeqaaaaakmaapedabaGaamyyaiaacIcacaWG0bGaaiykai aac6cacaWGKbGaamiDaaWcbaGaamiDamaaBaaameaacaaIXaaabeaa aSqaaiaadshadaWgaaadbaGaaGOmaaqabaaaniabgUIiYdaakiaawU facaGLDbaadaahaaWcbeqaamaalaaabaGaaGynaaqaaiaaikdaaaaa aaGccaGL7bGaayzFaaaaaa@5F44@
    With ( t 2 − t 1 ) < P e r i o d MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaiikaiaads hadaWgaaWcbaGaaGOmaaqabaGccqGHsislcaWG0bWaaSbaaSqaaiaa igdaaeqaaOGaaiykaiabgYda8iaadcfacaWGLbGaamOCaiaadMgaca WGVbGaamizaaaa@4296@ and a ( t ) = a c c e l e r a t i o n ( t ) g r a v i t y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyaiaacI cacaWG0bGaaiykaiabg2da9maalaaabaGaamyyaiaadogacaWGJbGa amyzaiaadYgacaWGLbGaamOCaiaadggacaWG0bGaamyAaiaad+gaca WGUbGaaiikaiaadshacaGGPaaabaGaam4zaiaadkhacaWGHbGaamOD aiaadMgacaWG0bGaamyEaaaaaaa@4E65@ .
    The sensor is activated when H I C P e r i o d > v a l u e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGibGaam ysaiaadoeadaWgaaWcbaGaamiuaiaadwgacaWGYbGaamyAaiaad+ga caWGKbaabeaakiabg6da+iaadAhacaWGHbGaamiBaiaadwhacaWGLb aaaa@4540@ after Tmin value.
