/SENSOR/RBODY
Block Format Keyword Describes the sensors used to activate or deactivate an object according to rigid body force.
| /SENSOR/RBODY/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| rbody_ID | DIR | Fmin | Fmax | Tmin | |||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| rbody_ID | Rigid body
| DIR | Force direction.
(Integer) |
| Fmin | Minimum
force. Default = 0 (Real, maximum 20 fields) |
| Fmax | Maximum
| Tmin | Minimum time duration
before activation when criteria is reached.
(Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type
RBODY:Sensor is activated when the force in the rigid body satisfies the criteria:
- or during Tmin
Dir defines Force or Moment output to monitor:- TF
- Total Force
- TM
- Total Moment
