/SENSOR/WORK
Block Format Keyword Describes the sensors used to activate or deactivate an object according to work.
/SENSOR/WORK/sens_ID/unit_ID
sens_title
Tdelay
node_ID1 node_ID2 Wmax Tmin
sect_ID int_ID rbody_ID rwall_ID
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
Wmax Maximum work.
Default = 0 (Real)
[ J ]
Tmin Minimum time duration before activation when criteria is reached. 3
(Real)
[ s ]
sect_ID Section identifier.
int_ID Interface or sub-interface identification number.
(Integer)
rwall_ID Rigid wall identification number.
(Integer)
rbody_ID Rigid body identifier.
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For sensor type WORK:
    Sensor is activated when work satisfies the criteria:
    W o r k > W m a x during Tmin
    W o r k = | ∫ x F ( sec t _ I D ) d x | + | ∫ x F ( r b o d y _ I D ) d x | + | ∫ x F ( i n t _ I D ) d x | + | ∫ x F ( r w a l l _ I D ) d x | MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4vaiaad+ gacaWGYbGaam4Aaiabg2da9maaemaabaWaa8qeaeaacaWGgbWaaeWa aeaaciGGZbGaaiyzaiaacogacaWG0bGaai4xaiaadMeacaWGebaaca GLOaGaayzkaaaaleaacaWG4baabeqdcqGHRiI8aOGaamizaiaadIha aiaawEa7caGLiWoacqGHRaWkdaabdaqaamaapebabaGaamOramaabm aabaGaamOCaiaadkgacaWGVbGaamizaiaadMhacaGGFbGaamysaiaa dseaaiaawIcacaGLPaaaaSqaaiaadIhaaeqaniabgUIiYdGccaWGKb GaamiEaaGaay5bSlaawIa7aiabgUcaRmaaemaabaWaa8qeaeaacaWG gbWaaeWaaeaacaWGPbGaamOBaiaadshacaGGFbGaamysaiaadseaai aawIcacaGLPaaaaSqaaiaadIhaaeqaniabgUIiYdGccaWGKbGaamiE aaGaay5bSlaawIa7aiabgUcaRmaaemaabaWaa8qeaeaacaWGgbWaae WaaeaacaWGYbGaam4DaiaadggacaWGSbGaamiBaiaac+facaWGjbGa amiraaGaayjkaiaawMcaaaWcbaGaamiEaaqab0Gaey4kIipakiaads gacaWG4baacaGLhWUaayjcSdaaaa@8105@
    Where,
    x
    Distance between node_ID1 and node_ID2
    F(sect_ID)
    Force in the selected section force
    F(rbody_ID)
    Force in the selected rigid body
    F(int_ID)
    Force in the selected contact interface
    F(rwall_ID)
    Force in the selected rigid wall
    If sect_ID is 0, F ( sec t _ I D ) = 0
    If rbody_ID is 0, F ( r b o d y _ I D ) = 0
    If int_ID is 0, F ( i n t _ I D ) = 0
    If rwall_ID is 0, F ( r w a l l _ I D ) = 0
    Work of all forces is calculated in the direction N1-N2, it is always positive.
    If node_ID2 is not defined (0), the distance x becomes the displacement of the node_ID1
