Creates a RBODY per part with the center nodes connected to the SPRING2N
element.
Restriction: Only available in Radioss.
Which nodes belong to the RBODY is determined with a defined cylinder volume. If a hole
per part can be found in the defined cylinder, only the nodes of the holes are
connected. Otherwise all nodes in the cylinder belong to the RBODY element (per
part).Figure 1.
