This realization creates a single ConNode rigidlink element (LS-DYNA) or RBE2 (Radioss) for the body, and
projects and connects to nodes of the adjoining shell/solid within the prescribed cylinder
diameter, L1 (cylinder height along the vector from the connector location) and L2 (cylinder
height in the opposite direction of the vector from the connector location).
Restriction: Available in LS-DYNA and Radioss.
The realization uses the prop_dyna_rigidbolts.tcl or
prop_radioss_rigidbolts.tcl property script.Figure 1.
