It connects to the nearest node to the connector position and then projects to the
nearest nodes on the adjoining elements of the connected components.
The dyna ConNode (spider) exists in exactly the same configuration with the following
additional names:
HC cylinder rigid bolt
HC cylinder rigid clip
This is in order to keep the realization names from HyperCrash.Figure 1.
