Creates KINCOUP elements for the head and B31 element for the body.
Restriction: Only available in Abaqus.
The head elements project and connect to the nodes of the adjoining shell elements that
form the hole, and also to the second row of nodes to form the washer layer. The
connector location can be on the edge of the hole, center of the hole, midpoint in
between the two, holes or on the second row of nodes which form the washer layer.
This connector uses the script prop_abaqus_b31.tcl.Figure 1.
