Material Behaviors
This entity defines additional material features coupled to the referenced material, like: Failure, Permeability, Porosity, Thermal, Fatigue, Cohesive, Inelasticity, and so on.
Material Behaviors are referenced in the Material Entity Editor, which allows for a complete view of the material definition.
制約事項: This entity is inly supported in the LS-DYNA profile.
LS-DYNA Cards
  • *MAT_ADD_AIRBAG_POROSITY
  • *MAT_ADD_CHEM_SHRINKAGE
  • *MAT_ADD_COHESIVE
  • *MAT_ADD_DAMAGE_DIEM
  • *MAT_ADD_DAMAGE_GISSMO
  • *MAT_ADD_DAMAGE_GISSMO_STOCHASTIC
  • *MAT_ADD_EROSION
  • *MAT_ADD_FATIGUE
  • *MAT_ADD_FATIGUE_EN
  • *MAT_ADD_GENERALIZED_DAMAGE
  • *MAT_ADD_INELASTICITY
  • *MAT_ADD_PERMEABILITY
  • *MAT_ADD_PORE_AIR
  • *MAT_ADD_PROPERTY_DEPENDENCE_FREQ
  • *MAT_ADD_PROPERTY_DEPENDENCE_TIME
  • *MAT_ADD_PZELECTRIC
  • *MAT_ADD_SOC_EXPANSION
  • *MAT_ADD_THERMAL_EXPANSION
PAM-CRASH Cards
Card Description
NLAVE
Non-Local Average Option Definition, specifies a spatial averaging procedure for internal variables such as energy, stress and plastic strain
RUPMO / Rupture model definition.
RUPMO / IRUPT = 0
Rupture Model Using Normal/Shear Load Criterion
RUPMO / IRUPT = 1
Rupture Model Using Stress Criterion
RUPMO / IRUPT = 2
Rupture Model Using a User-Defined Criterion for PLINKs
RUPMO / IRUPT = 3
Rupture Model Using a User-Defined Criterion for Spring-Beams
RUPMO / IRUPT = 5
RUPMO / IRUPT = 6
EWK Rupture Model (only for Material Types 16 and 117)
RUPMO / IRUPT = 7
Rupture Model Using Loads Criterion (Weighted Bending) for Material Types 223 and 224
RUPMO / IRUPT = 11
Rupture Models with User-Defined Criteria for Material Types 223, 224 and 302
RUPMO / IRUPT = 12
RUPMO / IRUPT = 13
PAM-CRASH Failures
Failures describe material failure criteria to be coupled to material models.
In PAM-CRASH 2G, Damage and Failure parameters of Modular material MMAT are defined through the Failure entity.
1. PAM-CRASH Cards
Card Solver Description Application Notes
MMAT /
FAILURE
GLOBAL_BEHAVIOR
Global Damage and Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
DUCTILE_CURVES
Ductile Damage by Curves Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
DUCTILE_LOOKU
Ductile Damage by Look-Up Tables Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
SHEAR_CURVES
Shear Damage by Curves Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
SHEAR_LOOKU
Shear Damage by Look-Up Tables Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
JOHNSON_COOK
Johnson-Cook Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
XUE_WIERZBICKI
Xue-Wierzbicki Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
MODIFIED_MOHR_COULOMB
Modified Mohr-Coulomb Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
ANISOTROPIC_FRACTURE
Anisotropic Fracture Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
FORMING_LIMIT_DIAGRAM
Forming Limit Diagram Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
MUSCHENBORN_SONNE
Müschenborn-Sonne Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
ENHANCED_HILL_STOREN_RICE
Enhanced Hill-Stören-Rice Failure Parameters Definition Damage and Failure Parameters Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
GENERALIZED_NECKING
Generalized Necking Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
PLASTIC_STRAIN_SOFTENING
Plastic Strain Softening Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
HILL_STOREN_RICE
Hill-Stören-Rice Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
MODIFIED_HILL_STOREN_RICE
Modified Hill-Stören-Rice Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
RELATIVE_THICKNESS
Relative Thickness Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
MAXIMUM_STRAINING
Maximum Straining Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
PLASTIC_STRAIN_DAMAGE
Plastic Strain Damage Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
EXTENDED_COCKCROFT_LATHAM
Extended Cockcroft-Latham Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
MMAT /
FAILURE
TABLE_DRIVEN_LOOKUP
Data-Driven Look-Up Table Failure Parameters Definition Elastic-plastic materials Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT /
