2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Draws the cursor.
Sets the cursor’s position to find the closest value to the input arguments.
Finds the cursor’s line’s color.
Finds the cursor line’s visibility.
Sets the cursor line’s color.
Sets the cursor line’s visibility.
Use the Task Manager to load an XML file that defines tasks and their attributes.
