2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Determines if the statistics template is editable.
Finds the name of the statistics template.
Finds the text within the statistics template.
Sets the statistics template to be editable or not.
Sets the name of the statistics template.
Sets the text within a statistics template.
Use the Task Manager to load an XML file that defines tasks and their attributes.
