2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Draws colored text.
Draws an ellipse.
Draws a filled ellipse.
Draws a filled rectangle.
Draws a line.
Draws a rectangle.
Gets a handle to an hwIFont interface for the draw control.
Use the Task Manager to load an XML file that defines tasks and their attributes.
