2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the label for a data attribute.
Gets the value for a data attribute.
Returns the type of data attribute.
Gets the variable name for a data attribute.
Sets the label for a data attribute.
Sets the value for a data attribute.
Use the Task Manager to load an XML file that defines tasks and their attributes.
