2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
Use the Task Manager to load an XML file that defines tasks and their attributes.
