2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Zooms the plot to within the given dimensions.
Fits the plot in the window.
Zooms into the x dimensions of the curve in the plot.
Zooms into the y dimensions of the curve in the plot.
Flips the positions of the x- and y-axis on the plot.
Memorizes the current view.
Centers the plot based on the chosen point and changes the axes accordingly.
Sets the current view to the view memorized with M1.
Sets the current view to the view memorized with M2.
Swaps the position of the two axes positions in complex plots.
Switches between the Real/Imaginary and Magnitude/Phase Complex plots.
Translates the contents of the current window to the given position.
Moves the axes up, down, left, or right based on the given string input.
Zooms into the plot.
Zooms out of the plot.
Use the Task Manager to load an XML file that defines tasks and their attributes.
