2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Adds a new parameter to the macro.
Applies the current macro.
Copies the given parameter for the current macro.
Gets the “create note” value for the current macro.
Gets the “create target” value for the current macro.
Returns the specified expression for the current macro.
Returns the value of the “hide inputs” flag.
Returns the name of the current macro.
Returns the text of current macro’s note.
Returns the number of parameters in the current macro.
Returns the number of entity parameters in the current macro.
Returns a handle to the specified parameter.
Returns the name of the target (curve) created by the current macro.
Returns the varname of the current macro.
Pastes the specified parameter, which has previously been copied.
Removes the specified parameter from the macro.
Sets the “create note” value for the current macro.
Sets the “create target” value for the current macro.
Sets the specified expression to be the given expression for the current macro.
Sets the value of the “hide inputs” flag.
Sets the name of the current macro to the specified name.
Sets the text of current macro’s note to the given text.
Sets the name of the target (curve) created by the current macro to the specified name.
Use the Task Manager to load an XML file that defines tasks and their attributes.
