2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the number of columns in the data extractor.
Gets the number of rows in the data extractor.
Gets the number of values in the data extractor.
Gets dependency list (data sources) from the extractor.
Gets the data values from the extractor.
Use the Task Manager to load an XML file that defines tasks and their attributes.
