2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the parameter string to pass to a context menu.
Returns the index of the axis.
Returns the specified key’s value.
Sets the specified metadata key to the specified value.
Use the Task Manager to load an XML file that defines tasks and their attributes.
