Jump to main content
API, Reference Guides
2024
Index
  1. Home
  2. API, Reference Guides
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperView
  6. poICFD_rake Class
  • Welcome
  • What's New
    View new features for version 2024.
  • Get Started
  • Tutorials
  • API, Reference Guides
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Python API
      The Python API documentation for HyperMesh applications.
    • Tcl/Tk Commands
      • Program with APIs for Beginners
      • Object Hierarchy
      • Tcl/Tk Classes
      • Script Use Cases
      • Tcl/Tk Example
      • Program with Tcl/Tk Command Tutorials
      • Tcl/Tk Commands
        • Framework
        • MotionView
        • HyperView
          • Hotspot Finder API Structure
          • HyperView - MultiCore APIs
          • poI3DViewCtrl Class
          • poIAdvancedQuery Class
          • poIAssembly Class
          • poIBestView Class
          • poICFD Class
          • poICFD_rake Class
            • poICFD_rake GetID
              Returns the ID of the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake GetIntegrationMode
              Returns the integration mode for the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake GetLabel
              Returns the label of the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake GetNumberOfSeeds
              Returns the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
            • poICFD_rake GetRakeGoemetry
              Returns the definition string of the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake GetType
              Returns the type of the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake SetIntegrationMode
              Specifies the integration mode for the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake SetLabel
              Sets the label of the rake in the CFD Plot/Streamlines panel.
            • poICFD_rake SetNumberOfSeeds
              Specifies the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
            • poICFD_rake SetRakeGoemetry
          • poICollisionCtrl Class
          • poICollisionSet Class
          • poIComplexCtrl Class
          • poIComponent Class
          • poIContourCtrl Class
          • poICrossSectionPlanar Class
          • poICrossSectionSet Class
          • poIExplosion Class
          • poIFBDCtrl Class
          • poIFLDCtrl Class
          • poIGraphicMaterial Class
          • poIImagePlaneCtrl Class
          • poIImagePlane Class
          • poIIsoValueCtrl Class
          • poILayerFilter Class
          • poILegend Class
          • poIMeasure Class
          • poIModel Class
          • poINote Class
          • poIPart Class
          • poIPartAssembly Class
          • poIPartSet Class
          • poIPost Class
          • poIPostManager Class
          • poIQueryCtrl Class
          • poIQueryDistanceRule Class
          • poIQueryExpressionRule Class
          • poIQueryExtremeRule Class
          • poIQueryIgnoreElemTypeRule Class
          • poIQueryIterator Class
          • poIQueryRule Class
          • poIQuerySetRule Class
          • poIRenderOptions Class
          • poIResultCtrl Class
          • poIResultMathCtrl Class
          • poIScalarDefine Class
          • poIScaleCtrl Class
          • poISCL Class
          • poISection Class
          • poISelectionSet Class
          • poIStressLinearizationCtrl Class
          • poISubcase Class
          • poISweepCtrl Class
          • poISymmetry Class
          • poISystem Class
          • poISystemCtrl Class
          • poITensorCtrl Class
          • poITensorDefine Class
          • poITextAttribute Class
          • poITracingCtrl Class
          • poITrackingSystem Class
          • poIVectorCtrl Class
          • poIVectorDefine Class
        • HyperGraph 2D
        • HyperGraph 3D
        • MediaView
        • TextView
        • HgTrans
        • TableView
        • Postquery Commands
        • Context Commands
        • Framework Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • Task Manager
      Use the Task Manager to load an XML file that defines tasks and their attributes.
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
poICFD_rake Class
Note: See the CFD Post-Processing and Streamlines topics in the HyperView User's Guide for additional information.
  • poICFD_rake GetID
© 2024 Altair Engineering, Inc. All Rights Reserved.
