2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Positions the iterator to the first result item.
Gets the query results for the current entity.
Gets the description of the error that occurred.
Gets the current iterator ID.
Moves the iterator to the next item.
Checks for iterator validity.
Use the Task Manager to load an XML file that defines tasks and their attributes.
