2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the value of a given attribute of the part assembly.
Gets the list of attributes that can be passed to poIPartAssembly GetAttribute.
Gets the list of IDs for the part assemblies that are children of a part assembly in the part hierarchy.
Gets the part assembly color as an RGB value.
Gets the part assembly color as an index value in the color palette.
Gets the part assembly ID.
Gets the ID of the parent of a part assembly in the part hierarchy.
Gets a copy of the poISelectionSet handle which holds the components that are contained within a part assembly.
Gets the transformation matrix information.
Gets the part assembly type ("PLMXML" or "User").
Gets the part assembly visibility.
Sets the part assembly visibility.
Use the Task Manager to load an XML file that defines tasks and their attributes.
