Jump to main content
API, Reference Guides
2024
Index
  1. Home
  2. API, Reference Guides
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperView
  6. poIPart Class
  • Welcome
  • What's New
    View new features for version 2024.
  • Get Started
  • Tutorials
  • API, Reference Guides
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Python API
      The Python API documentation for HyperMesh applications.
    • Tcl/Tk Commands
      • Program with APIs for Beginners
      • Object Hierarchy
      • Tcl/Tk Classes
      • Script Use Cases
      • Tcl/Tk Example
      • Program with Tcl/Tk Command Tutorials
      • Tcl/Tk Commands
        • Framework
        • MotionView
        • HyperView
          • Hotspot Finder API Structure
          • HyperView - MultiCore APIs
          • poI3DViewCtrl Class
          • poIAdvancedQuery Class
          • poIAssembly Class
          • poIBestView Class
          • poICFD Class
          • poICFD_rake Class
          • poICollisionCtrl Class
          • poICollisionSet Class
          • poIComplexCtrl Class
          • poIComponent Class
          • poIContourCtrl Class
          • poICrossSectionPlanar Class
          • poICrossSectionSet Class
          • poIExplosion Class
          • poIFBDCtrl Class
          • poIFLDCtrl Class
          • poIGraphicMaterial Class
          • poIImagePlaneCtrl Class
          • poIImagePlane Class
          • poIIsoValueCtrl Class
          • poILayerFilter Class
          • poILegend Class
          • poIMeasure Class
          • poIModel Class
          • poINote Class
          • poIPart Class
            • poIPart ApplyDefaults
              Sets the part material to default values.
            • poIPart GetAutoColor
              Gets the part auto color index.
            • poIPart GetColor
              Gets the part color index.
            • poIPart GetDefaultColor
              Gets the part default color index.
            • poIPart GetDisplayMode
              Gets the part display option setting.
            • poIPart GetDisplayModeList
              Gets the list of part display modes.
            • poIPart GetEulerAngles
              Gets the Euler angles with respect to the transform set by the call to poIModel SetRelativeTo.
            • poIPart GetID
              Gets the part's ID.
            • poIPart GetIDVisibility
              Gets the part's ID visibility.
            • poIPart GetLabel
              Gets the part's label.
            • poIPart GetLocator
              Gets the internal locator string for a part (for internal use only).
            • poIPart GetMaterial
              Gets the part material ID (zero if none assigned).
            • poIPart GetMaterialID
              Gets the ID of the material related to a component.
            • poIPart GetMaterialName
              Gets the name of the material related to a component.
            • poIPart GetMeshMode
              Gets the part's mesh mode.
            • poIPart GetOrientation
              Gets the orientation in the local coordinate system.
            • poIPart GetOrigin
              Gets the origin with respect to the transform set by the call to poIModel SetRelativeTo.
            • poIPart GetPartAssemblyID
              Gets the ID for the part assembly that contains a component.
            • poIPart GetParentID
              Gets the part's parent assembly ID.
            • poIPart GetPolygonMode
              Gets the part's polygon mode.
            • poIPart GetPool
              Gets the part's pool label.
            • poIPart GetPoolType
              Gets the part's pool type.
            • poIPart GetPosition
              Gets the position in the local coordinate system.
            • poIPart GetPropertyName
              Gets the ID for the property related to a component.
            • poIPart GetRelativeTo
              Gets the positions relative to the parent assembly, local or global.
            • poIPart GetScale
              Gets the scale factors for each coordinate axis.
            • poIPart GetShadeMode
              Gets the shading mode for a specific part and overrides the global setting that was set with poIRenderOptions GetShadeMode.
            • poIPart GetTracingMode
              Gets the part's tracing mode.
            • poIPart GetType
              Gets the part type's string.
            • poIPart GetVisibility
              Gets the part's visibility.
            • poIPart Rotate
              Rotates the part about the axis and angle.
            • poIPart SetAutoColor
              Sets the part's auto color index.
            • poIPart SetColor
              Sets the part's color index.
            • poIPart SetDefaultColor
              Sets the part default color index.
            • poIPart SetDisplayMode
              Sets the part's display mode.
            • poIPart SetEulerAngles
              Sets the Euler angles (Z-X-Z) with respect to the system defined by the call to poIModel SetRelativeTo.
            • poIPart SetIDVisibility
              Sets the part's ID visibility.
            • poIPart SetLabel
              Sets the part's label.
            • poIPart SetMaterial
              Sets the part's material index.
            • poIPart SetMeshMode
              Sets the part's mesh mode.
            • poIPart SetOrientation
              Sets the part's orientation in the local coordinate system by the given Euler angles ZXZ.
            • poIPart SetOrigin
              Sets the part origin in the local coordinate system by the given vector.
            • poIPart SetPolygonMode
              Sets the part's polygon mode.
            • poIPart SetPosition
              Sets the part position in the local coordinate system by the given vector.
            • poIPart SetRelativeTo
              Sets positions relative to the parent assembly, local or global.
            • poIPart SetScale
              Sets the part scale factors for each axis.
            • poIPart SetShadeMode
              Sets the shading mode. This command overrides the global setting that was set with poIRenderOptions SetShadeMode.
            • poIPart SetTracingMode
              Sets the part's tracing mode.
            • poIPart SetVisibility
              Sets the part's visibility.
          • poIPartAssembly Class
          • poIPartSet Class
          • poIPost Class
          • poIPostManager Class
          • poIQueryCtrl Class
          • poIQueryDistanceRule Class
          • poIQueryExpressionRule Class
          • poIQueryExtremeRule Class
          • poIQueryIgnoreElemTypeRule Class
          • poIQueryIterator Class
          • poIQueryRule Class
          • poIQuerySetRule Class
          • poIRenderOptions Class
          • poIResultCtrl Class
          • poIResultMathCtrl Class
          • poIScalarDefine Class
          • poIScaleCtrl Class
          • poISCL Class
          • poISection Class
          • poISelectionSet Class
          • poIStressLinearizationCtrl Class
          • poISubcase Class
          • poISweepCtrl Class
          • poISymmetry Class
          • poISystem Class
          • poISystemCtrl Class
          • poITensorCtrl Class
          • poITensorDefine Class
          • poITextAttribute Class
          • poITracingCtrl Class
          • poITrackingSystem Class
          • poIVectorCtrl Class
          • poIVectorDefine Class
        • HyperGraph 2D
        • HyperGraph 3D
        • MediaView
        • TextView
        • HgTrans
        • TableView
        • Postquery Commands
        • Context Commands
        • Framework Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • Task Manager
      Use the Task Manager to load an XML file that defines tasks and their attributes.
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
poIPart Class
Note: See and Entity Editor - Component/Parts in the HyperView User's Guide for additional information.
  • poIPart GetColor
  • poIPart GetID
    Gets the part's ID.
  • poIPart GetLabel
  • poIPart GetOrigin
  • poIPart GetPool
  • poIPart GetScale
  • poIPart GetType
  • poIPart Rotate
  • poIPart SetColor
  • poIPart SetLabel
  • poIPart SetOrigin
  • poIPart SetScale
© 2024 Altair Engineering, Inc. All Rights Reserved.
