2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Adds entities to the selection set.
Clears the selection set from all if its entities.
Retrieves the visible color setting on the current selection.
Gets the draw size of the current selection set.
Gets the draw style of the current selection set.
Gets a list of valid draw styles for the current selection set.
Retrieves the ID of the current selection set.
Retrieves the visibility setting for the entity IDs of the current selection set.
Retrieves the label of the current selection set.
Retrieves the list of all entity IDs on the current selection set.
Gets the pool name for the current selection set.
Retrieves the list of pool names over all entities in the current selection set.
Retrieves the list of pool name and ID ranges.
Retrieves a list of valid selection methods to be used as arguments on the selection set commands Add and Subtract.
Retrieves a list of previously applied selection rules for the selection set.
Retrieves the current selection mode of the selection set.
Retrieves a list of possible values for the selection mode.
Retrieves the number of entities of the current selection set.
Retrieves the current data type for the selection set.
Retrieves the visibility setting of the current selection set.
Reverses the selection of entities on the selection set.
Sets the visibility color on the current selection set.
Sets the draw size of the current selection set.
Sets a particular draw style on the current selection set.
Sets the visibility status for entity IDs of the current selection set.
Sets the label of the current selection set.
Sets the selection mode of the selection set.
Sets the visibility of the current selection set.
Subtracts entities from the selection set.
Use the Task Manager to load an XML file that defines tasks and their attributes.
