2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the ID of the query rule.
Gets the label from the query rule.
Gets the type of the query rule.
Sets the label to the query rule.
Use the Task Manager to load an XML file that defines tasks and their attributes.
